09-10-2019, 08:46 AM | #113 |
i dont know why they dont recommended oil for the diffs anymore. it just takes regular 75w90 with friction modifier. Amsoil already has it in it. its fine to use. i have been for almost 13,000 miles works fine. I just put there ATF in my trans but i did a Hurst shifter at the same time. I think i have a bad 2nd gear synchro befor. havent gotten on it to see if it still grinds and locks me out at 4000rpm going into 2nd. skip shift is turned off in the tune but dynosteve messed up my skip shift when he put a canned SCT tune in it instead of the $650 dyno tune I payed for. It started to grind when his tune would lock me out of 2nd 3rd and 5th and i had to shut the car off to get it to go back in those gears.
09-12-2019, 09:27 AM | #114 |
I just got in Redline Full Synthetic D4 ATF. No additive is needed for this fluid correct? I had this in my 2010 SS and loved it. I have a 2018 1LE now.
09-12-2019, 10:50 AM | #115 |
Drives: 2017 ZL1 Join Date: Jun 2018
I did mine yesterday. Used Amsoil for the trans and delco for the diff. 26000 and they both looked pretty clean. Now I have to flush my brake fluids before the next track days
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
09-13-2019, 08:02 PM | #116 |
Drives: 2018 2SS M6 Redline Join Date: Oct 2014
Nothing else is needed. Drives much better with Redline D4.
03-30-2020, 04:24 PM | #117 |
instead of using a 1/8' bent wire you can fill it till fluid comes out then you remove 240ml (8oz)of fluid. To fill you fill until fluid comes out then you start the car with the trans in neutral. Do not compress clutch pedal and idle for 2 min then shut car off and fill trans. the trans actually takes 5.2qts with cooler.
06-04-2020, 08:31 AM | #118 |
Drives: Black 2019 ZL1 M6, Join Date: Sep 2019
subed
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
06-11-2020, 04:52 PM | #119 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
While I am certain the events were not related, about a month after I switched to D4, I had a serious issue with my transmission that required it to be dropped and rebuilt. It was covered under warranty.
I spoke with Tremec and will now only be running their fluid. https://www.tremec-store.com/collect...smission-fluid
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
06-11-2020, 05:11 PM | #120 | |
Drives: blue velvet Join Date: Jul 2018
Curious what your issue was. I'm about to change mine with D4. |
07-11-2020, 03:01 PM | #121 |
BTW - Tremec mentioned that they do not require the 8oz drain out procedure if you use their fluid. That is for the expansion properties of ATF.
The Tremec fluid is almost clear. And it doesn't smell horrible like ATF.
2017 HBM SS 1LE
08-14-2020, 02:14 PM | #122 |
Drives: 2017 1SS 1LE Join Date: Jan 2018
That's a nice property. Is it documented anywhere by Tremec or GM?
2017 Camaro 1SS 1LE - Stock for now
2015 VW Golf R DSG - GIAC ECU/TCU tune |
01-07-2021, 09:26 PM | #123 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
Just did this swap, figured I’d add my 2 cents. I saw the PDF from the manual and a YouTube video that says to drain from the temperature sensor, so that’s what I did. I was looking around while I was under there, and couldn’t help but notice the rear plug was lower than the temp sensor. My small brain tells me...I should investigate. I supported the tranny with a jack and a block of wood and undid the crossmember, what a cake walk! Glad I got that out of the way to gain access. Once I took the drain plug out I was glad I did since a GOOD amount of fluid came out! My advice, skip the temp sensor and go right for the crossmember removal and rear drain plug. I had a flickering light bulb moment I’d like to share to help reduce or in my case eliminate the mess from draining. I placed my funnel as shown in the picture to “catch” all the fluid and redirect it right to the drain pan. No muss no fuss! Last light bulb moment was checking the fluid level. 1/8? 8oz? Mechanic wire? Pffft. I slid my trusty iPhone up in there and turned the flash on and took a picture. I could easily make out the level that way and call it good.
PS if you don’t have a MityVac or similar professional grade pump it’s worth whatever they charge x2. I have the MV6400.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
01-14-2021, 09:15 PM | #124 | |
Drives: 2017 1SS 6spd Join Date: Jan 2011
I'm changing back to RP GearMax 75w-90 (had tried Motul and it is worthless in cold weather). Thank you for your insight! |
01-16-2021, 06:27 PM | #125 |
Changed the trans fluid again today, but just for fun decided to pull the temp probe to drain this time (mostly cuz I'm lazy) but was surprised to get 3.65 L. back.
Overall, now that I know its just 6 easily accessible bolts (re-torqued to 43 ft/lbs) to give easy access to the "real" drain, I'll use that route in the future. Anyone have some more input as to the procedure to clear the manual trans cooler when you're doing this? BTW- I did the staff of Ra procedure to drop the total fluid I left in the trans this time . Name that film? |
01-17-2021, 09:00 AM | #126 |
BLEW BIU
Drives: 2018 2SS 1LE Hyper Blue Join Date: Oct 2017
Indiana Jones, right?
