07-18-2016, 09:06 AM | #1 |
New Nitto D/R's took off 4/10ths on my SS M6
I brought a set of Nitto D/R's last week and got to make a pass with them on the weekend. First pass I was 12.49 @ 115.99 MPH. I didn't get to make any more passes as track was real busy. I figure I can get down to 12,2 with just heating tires up before my run.
07-18-2016, 09:12 AM | #2 |
Drives: 21 Bronco Join Date: Jun 2012
Nice time, which Nitto did you go with? The 555R or the NT05R?
07-18-2016, 09:19 AM | #3 |
07-18-2016, 09:22 AM | #4 |
Drives: 2018 Redline Edition 2SS Join Date: Dec 2014
Yeah you should have a way better 60' time than that...get that down and watch your 1/4 time dip a lot more.
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD. Last edited by FrostySS; 07-18-2016 at 09:35 AM. |
07-18-2016, 09:30 AM | #5 |
Drives: '98 Pontiac Trans Am Join Date: May 2016
Just curious, that's a ZL1 you ran against correct? from the time slip it looks like he had you to the 1/8th on time but you were already closing the gap at +5mph at the 1/8th and pulling even harder on him at +10mph at the 1/4 very impressive.
I was a little confused buy the pictures relating to your time slip I see your car is marked ?810 which lines up with the 7810 time slip car running 12.492 but that is the right lane car and in the drag-strip picture your '16 is in the left lane? Not trying to create drama, just curious why they don't match.
2017 1LE Camaro Hopeful
1998 Trans Am M6, Bolt Ons (Daily Driver) 2005 Eddie Bauer Expedition (Family Vehicle) 2007 Z51 Corvette M6 (Salvage Project Car) 1987 Trans Am 350tpi A4 RIP |
07-18-2016, 09:30 AM | #6 |
Like I said I made only 1 pass as it was so busy. I didn't heat tires up other than a small burn out to clean them up as I thought I would get more passes but a guy blew up and everything was way behind. Will go to T&T this week and play around a bit more.
07-18-2016, 09:32 AM | #7 | |
07-18-2016, 09:35 AM | #8 |
07-18-2016, 09:39 AM | #9 |
Toyota Tech
Drives: 2SS A8 Join Date: Jul 2014
60ft is weak. people cutting better 60ft with stock tires.
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114 Sold 2013 Chevy Crzue LTX |
07-18-2016, 09:42 AM | #10 |
no problem at all, I was really surprised that a ZL1 got out of the hole faster than you and then you were able to run him down and pass him
makes more sense now
07-18-2016, 09:44 AM | #11 |
OP said he was only able to do a small burnout on his 1 pass he made. My previous experience with Nitto DR's is that they really need to vbe heated up to get sticky. At least that is how the NT555R's were
07-18-2016, 09:45 AM | #12 |
60' is going to be improved with seat time, doesn't matter if it's DR or factory, I would expect someone with a lot of passes at a particular track with factory tires to cut a great 60' while this is Steve's 1 and only pass on DR's. His times will drop as he gets a feel for the tire/car/track
07-18-2016, 09:50 AM | #13 | |
07-18-2016, 10:07 AM | #14 |
Drives: Coupeless :( Join Date: Jan 2015
There are people with 1.7 60' times on stock tires. I'm not sure how much you will be able to improve on that, but you would hope that DR tires would make a time like that more repeatable.
