dave@hennessey
Old 11-02-2021, 03:24 PM   #1
jneil92
Drives: 2015 1LE
Question Whats Your Lifter Preference?
I know this has been talked about on a million other posts but I'm curious to know what everyones personal preference is for lifters. If you had to get a new set of lifters today what would you personally choose? I like the Chevrolet Performance lifters myself
jneil92 is offline   Reply With Quote
Old 11-02-2021, 05:51 PM   #2
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
I guess it depends on your combo.
A good GM/Delphi LS3/LS7 works well for most street applications where it will peak at 6500-6700RPM
Lots got with the GM Performance racing lifters if they like to rev 7000+ or hard abuse.
Morel and Johnson has some nice lifters too.
On my car, I run the Johnson short travel/slow leak down race style lifter.
Very happy with them,think it's the quietest lifter that I've used so far.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 11-02-2021, 05:59 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I am running the Delphi LS7's in my engine, thinking about changing to the Johnson LSR 2116's because my setup makes power above 6800 all the way to 7500.. When I'm on it I normally am between 6800 and 7200. Granted I don't go there all the time, but I can and want to make sure my lifters can handle it. Been ok so far.
1JEWLDSSRS is offline   Reply With Quote
Old 11-02-2021, 06:53 PM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
I've used ls3/7 lifter in many builds, Delphi or GM. These cars see severe duty and high rpms. I have had zero issues. I have also used Johnsons and GM race lifters with the same result. Prep, proper install, and proper oiling keeps lifters alive.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 11-02-2021, 09:46 PM   #5
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
The GM Performance lifters have been good to me. 7800rpm on the dyno, 7600rpm redline and have had nothing but good results
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 11-03-2021, 02:57 AM   #6
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Under 7000rpm genuine LS7 lifters are fine with new trays. Over 7000rpm go with a race lifter. I went Johnson.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 11-03-2021, 03:14 AM   #7
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I just replaced my gm performance lifters because I had a pretty loud lifter tap after 7k miles with the GPI SS1 camshaft. I switched them out for the gm performance racing lifters with good results. The performance ones are rated to 7000 rpm and the racing version are good to 8000 rpm and their lighter for better valve control. I've actually revved my engine to 6800 rpm, pretty close to their limit so I just did it mainly for piece of mind. The racing ones also use the same preload as the performance / ls3 lifters too. If you don't mind measuring lifter preload then I would go with the johnson's.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 11-03-2021, 05:53 AM   #8
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Chevrolet Performance lifters here with current set up and would use them again. Used the GM LS7 lifters in my previous build with no issues.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 11-03-2021, 11:58 AM   #9
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
If you can afford it, i would do a solid roller cam from cam motion,
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 11-08-2021, 12:05 AM   #10
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Did you stay with the trays or go with a link bar setup?
Curious what you think about link bars. Worth being able to go with lifter trays and gain that extra peace of mind or is that just introducing another possible failure point?
InFiD3ViL is offline   Reply With Quote
Old 11-08-2021, 06:25 AM   #11
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
FasNuf is offline   Reply With Quote
Old 11-08-2021, 06:42 AM   #12
Bo White
Bo White's Avatar
I run the 2116 link bars. Link bars are more reliable imo.
Totalled:
Old 11-08-2021, 09:06 AM   #13
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
Hi sir . Was wondering running the 2116 lsr did you end up with two different pushrod measurements? Thank you
Risingson05 is offline   Reply With Quote
Old 11-08-2021, 07:32 PM   #14
Bo White
Bo White's Avatar
I did. 7.700 and 7.675 I think.
A couple were a smidge off from where they are supposed to be but so far so good.
Totalled:
