01-25-2022, 07:36 PM | #1 |
Drives: 2010 Camaro 2SS/RS A6 Join Date: Jul 2021
Thermostat
Hi all, I have the stock thermostat on my 2010 Camaro SS. See below what all I've done, but basically SS3 cam and supporting mods, has 60k miles. I live in AR and VA. It's a daily driver, no track runs. Most of the year ECT runs 195° to 205°F, in summer heat I see it up to 215° some times. All in normal ranges but I'm considering a slightly lower thermostat (180 or 175). What do you recommend? TIA! PFA.
2010 2SS/RS A6. GPI SS3 VVT Cam, 228/246 / AFM Delete / Circle D 4C 36-3800 Stall / Stainless Works LTHs, High Flow Cats, X-pipe, Borla Pro XS Mufflers and Quad Tips / Vararam CAI / Soler 95mm PTB / AAM 3.91 gear / GPI Ported Heads / GPI Ported Rod Mod Intake Manifold/ Smith Bros. Trunnions / GPI 5/16" hardened push rods, 7.425"/ Chevrolet Racing Lifters / Melling 10355 Oil Pump / Powermaster XS Torque Starter / Derale Xmsn Cooler / 1LE Suspension Upgrade System / BMR Strut Tower Brace, Trailing Arms and Toe Rods / Powerbond 25% UDP / Mishimoto catch can / iDatalink Maestro.
01-25-2022, 08:16 PM | #2 |
I use the Mishimoto 167 thermostat in mine. I live in AR as well. Check with Ryan or Ben (depending on who tuned your car) on getting the cooling fans updated to come on sooner as well.
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
01-25-2022, 11:34 PM | #3 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
It's not broken, don't fix it. If you must do something then have the fans come on a bit sooner as mentioned.
01-26-2022, 08:25 AM | #4 |
376 cubic inches of fun
A lower temp thermostat will not lower the steady state temperature. It will open sooner, but once it's open and you keep driving, you'll get to the same 215 degrees on a hot day as before.
There's more to be gained from turning on the fans at a lower temp. They will stay on over a wider range and remove more heat. |
01-26-2022, 08:32 AM | #5 |
Hi! Yeah, Ben tuned it (and then re-tuned it when I was having that strange 2000 rpm idle on cold start problem). I'm dropping it off in April for a few things so I'll have Ben adjust the fan parameters.
01-26-2022, 09:43 AM | #6 |
I'm running a Mishimoto 169 in mine after seeing some of the testing "acammer" who works with the GPI guys has done on his Camaro, also I have the fans coming on sooner as well in my tune. On a hot summer day in stop and go traffic it never gets over 201. Cruising at speed she will stay right around 187-189..
01-26-2022, 12:06 PM | #7 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
^^^These are the results I see. I put in a 160ish stat and had the fans come on earlier and it rarely breaks 200 unless tracking and then 207 is about max. It really helps keep the temps down drag racing because you are not running that long so that little bit of additional time with the stat open matters. Some guys even jumper the fan relay to run the fans constant between runs. Others will tell you it makes no difference on ET, but I prefer to keep it cooler.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
01-26-2022, 12:18 PM | #8 |
Instagram: Sangstah
Mishimoto 169 degree t stat here too, works great and the car never gets hot even pushing it in the canyons.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
01-26-2022, 01:18 PM | #9 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
https://www.camaro5.com/forums/showthread.php?t=72524
More reading on the topic. |
01-26-2022, 04:43 PM | #10 |
I run a 160º stat in mine and never break 200º, but I am in Florida, so it serves it's purpose well. I was tired of hitting 215º+ in the summer and having timing pulled. With the 160 stat I am usually between 172 - 192º.
Just make sure to get a retune to have your fan profile changed so they come on sooner.
