Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Suspension / Chassis / Brakes
Old 01-18-2022, 03:42 PM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
2016-2020 Camaro BMR UTCA060 Upper Trailing Arm On-car Adjustable Rod Ends
Launching harder, reducing wheel hop, and adding cornering consistency to your 2016-newer Chevrolet Camaro is easy with upper trailing arms from BMR Suspension. Stock-stamped steel control arms with soft rubber bushings deflect under load and absorb power instead of transferring it to the tires. BMR’s rod-ended, on-car adjustable trailing arms for Camaros (UTCA060) are manufactured from heavy-duty 1.25-inch DOM steel tubing with TIG-welded Chrome-moly tube adapters. This design gives you a strong trailing arm that eliminates deflection and greatly improves performance. The UTCA060 features a zinc-plated two-piece, X-series, heat-treated, chrome-moly, self-lubricating, Teflon-lined rod ends. It also features 304 stainless steel, custom-designed rod end spacers. This design provides reduced deflection, increased articulation, and an all-around improvement in performance
BMR Suspension designed the UTCA060 to work well in street performance, drag race, and road race applications. The stock trailing arms flex under cornering loads giving you inconsistent handling characteristics. Combine this with soft bushings that have massive amounts of deflection and you’re left with poor performance. The UTCA060’s heavy-duty construction eliminates trailing arm flex, giving you much-improved repeatability on the street, starting line, or in the corners. BMR’s rod ends allow for fine-tuning and bind-free suspension articulation needed for superior handling at any power level. When performance is a must, rely on BMR Suspension!
BMR Suspension’s UTCA060 on-car adjustable upper trailing arms are available in red and black hammertone powdercoat for long-lasting good looks. Installation time is about 1 hour. Proudly made in the U.S.A.
- Fits all 2016-newer Chevrolet Camaros
- On-car adjustable design
- Heavy-duty zinc-plated two-piece, X-series, heat-treated, chrome-moly, self-lubricating, Teflon-lined rod ends
- Built from 1.25-inch DOM steel tubing
- TIG-welded Chrome-moly tube adapters
- Eliminates trailing arm flex
- Eliminates bushing deflection
- Designed for street performance, drag race, and road race applications
- Durable powdercoat finish
- 1 hour installation time
- Proudly designed in the U.S.A.
- Proudly made in the U.S.A.
Available Colors
Black Hammertone Powercoat
Red Powercoat
Fitment: 2016, 2017, 2018, 2019, 2020 Camaro
RPIDon is offline   Reply With Quote
Old 03-31-2023, 02:59 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Old 04-08-2023, 05:28 AM   #3
RPIDon
RPIDon's Avatar
Drives: Camaro
Thank You for shopping at https://www.rpidesigns.com/shop/item...able-rod-ends/
