01-15-2022, 08:09 PM | #1 |
Drives: 2013 Camaro 2LT RS Join Date: Sep 2021
Question about lugging
Hello all! I own a 2013 Camaro 2LT RS w the LFX and 6l50.
I was curious, is it possible to lug the motor in this car? I have muffler delete so I can hear how hard the motor is trying to work and at low engine speeds (1.3k-2k) I can hear the motor working harder, putting out a much deeper tone. It doesn’t ever shake the car though (at least I don’t think) I’m sure in ‘D’, the motor could never lug itself (at least I hope not), but what about manual mode under these circumstances: Accelerating to 40mph in 3rd, then cruising in 3rd letting the rpms drop to 1k-1.5k, then trying to accelerate while still in 3rd. The revs will climb just fine (albeit slowly) but the exhaust makes a noticeably deeper tone. Is this lugging ? I guess my question is: If the rpms are too low for the car to accelerate, will manual mode automatically drop a gear until the rpms rise? Or will the motor allow itself to lug. |
01-17-2022, 09:05 AM | #2 | |
01-17-2022, 09:07 PM | #3 |
Yes you answered my question! So what engine load % do you try to keep it around?
01-17-2022, 09:43 PM | #4 | |
Drives: Never just fly under the radar Join Date: Jul 2015
Old Skool |
01-18-2022, 04:24 PM | #5 |
Most of the time I'm cruising around trying to keep it right around 40% or less, usually right around 38%. You will be turning more rpm's a bit, but the load will be lower. I do drive around town in "manual mode" a lot to keep my converter locked and trans cool. When I want to drive her hard, I will put it back in "sport" and let the computer do it's thing, this way I have the "flash" of the converter and auto downshift when needed to "blast off"!! lol.
01-18-2022, 04:25 PM | #6 |
Yes sir!! You'd be surprised at what you see while your driving in different situations. I scan all kinds of parameters with mine, they are really cool!!
01-20-2022, 01:10 AM | #7 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
While driving my stock '15 2LS V6 car today I attempted to duplicate the condition mentioned by OP. In manual mode I tapped up to 3 and accelerated to 40 mph. I then allowed vehicle to slow down until RPMs were about 1200. I briskly applied some gas pedal and indeed transmission shifted down to 2ND and it held there until about 4000 or so then shifted back to 3rd. I tried the same exercise again but SLOWLY applied pedal pressure and trans did NOT downshift. No lugging noted. Not exactly a controlled experiment but fun and informative none the less.
01-20-2022, 08:27 PM | #8 | |
01-22-2022, 10:58 AM | #9 | |
01-22-2022, 04:55 PM | #10 |
Give speed a chance
Pretty sure V6 and V8 are completely different. My shifter just has a D or M. One button for traction control "on" or "off". If you use the tap shifter in D nothing happens. My car is a 2LS, not sure about the 2LT or RS models.
01-23-2022, 10:01 AM | #11 |
Cool. Yea I was thinking they were kinda different. Correction on mine on the shifter, mine as well shows an "M" on the console, below the "D", but on the dash it will show the "S" when it is in "sport mode", and when you tap down, or tap the up button it will show the "M" for being in manual mode, and which gear you are currently in until you tap and "hold" the up button for 3 seconds, then it will be back in sport mode again showing the "S".. Really neat feature.
Tags |
lugging, manual mode, paddle shifters |
