01-15-2022, 04:11 PM | #15 |
Drives: 2016 Camaro SS Join Date: Jul 2020
Isn't max hp on a P1SC like 800 crank hp? Im not sure why you would go +30's unless you plan to update your head unit but not a bad idea to buy once vs lt4 then re-buy and at that point you could also just look at PI.
01-15-2022, 05:20 PM | #16 |
Drives: 2018 1SS 1LE Join Date: Jul 2012
I’m at 707 wheel with the P1SC. Also Only at 7-8 lbs of boost…..4inch pulley. Discussing plans with my builder as we speak to up the boost to 10lbs. I think 800 is based on stock cam.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
01-15-2022, 05:38 PM | #17 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
01-15-2022, 07:27 PM | #18 | |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Did you upgrade fueling components (Injectors Fuel pumps)? Is your engine otherwise stock / SBE? |
01-15-2022, 08:27 PM | #19 | |
Intake: 228 @ .050 Exhaust: 240 @ .050 Intake lift: .646” Exhaust lift: .646” Lobe separation: 116
2009 Pontiac G8 GT—605rwhp, SOLD Last edited by MSU120; 01-15-2022 at 09:14 PM. |
01-16-2022, 06:53 PM | #20 | |
01-16-2022, 07:44 PM | #21 |
Completely stock, with stock fuel and only the procharger, with procharger canned tune, the car dynoed at 545. After adding just LT4 fuel and doing a custom tune, it dynoed at 589 (same dyno). 707 was also on the same dyno. Boost level has been the same throughout the build process.
01-16-2022, 07:56 PM | #22 | |
Drives: 21 Lt1 Join Date: Dec 2016
01-16-2022, 08:01 PM | #23 | |
01-16-2022, 09:51 PM | #24 |
Nice power!! How much boost you running with those numbers? I may just try to run with 5psi 1st and see if my setup can support the e85 and go up from there. If it makes 550 whp to 625 whp on e85 I’d be happy. I’m sure it will be a blast. I just want to have the extra safety with e85 on sbe. Thanks
01-16-2022, 09:53 PM | #25 | |
01-16-2022, 09:58 PM | #26 |
7-8lbs peak boost. I’ve had the same boost level for each step in the build process. Yes….they do all my work, including the tune. (I’ve been going there for years.) I want E for same reason you do…..I just don’t think I can make it work.
01-16-2022, 10:07 PM | #27 |
Right on. Thx for the feedback. Now it has me thinking this might not be possible. I’m gonna stay hopeful for now. Thing has to be a blast to drive? Ever take it to the track?
01-23-2022, 06:20 PM | #28 | |
LT4 Fueling @~ 7.5-8 PSI on Pump 93 everything else stock LT1 resulting in 589 R-WHP is a respectable figure, provided it can last a while, without breaking the stock ring-lands as a DD-Spirited street car. |
