01-14-2022, 07:15 PM | #1 |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
Car bogs down on 0-60 Using Launch Control
Yesterday I did some 0-60 runs and after 2 successful runs 4.2 and 4.3 the car would fall flat and hesitate before launching. This happened 3 times in a row and the car had 30 minutes between the 2 successful runs and the additional 3 bogged down runs. It's a 2017 2 SS A8. I then tried a run without launch control and it did not bog. I ran a diagnostic from a OBD2 reader and no codes. Any ideas? Could the AFM cause this? Seems the it only does it when Launch control is used.
01-14-2022, 07:25 PM | #2 |
Drives: Camaro SS 1LE Join Date: Aug 2018
It’s probably the Nannie’s built in to protect the drive train. After market throttle body may help.
01-14-2022, 09:42 PM | #3 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
I had the same thing when I first started using launch control. Seems like something is wrong but its killing timing to stop the spinning and completely normal. Its how it modulates the power. a log will show the timing going up and down.
01-15-2022, 07:39 AM | #4 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I think it is normal. When I do launch control, you can tell it is pulling a lot of timing at first so that there is traction.
When I just hammer it from a stop, the car will spin, shift to 2nd, spin, shift to 3rd, spin and then get traction. These LT1 engines are just plain beasts. Launch control is reigning in the beast for traction. |
01-15-2022, 08:34 AM | #5 | |
Makes since specially sine the outside temperature dropped a couple degrees to 69 degrees when I did the second set of 0-60 runs. Guess the Michelin 4S tires got cold and couldn't hold her back enough. |
01-16-2022, 10:33 PM | #6 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
So for whatever reason GM really screwed up the launch control calibration, at least on the SS'es. This is normal and it pulls timing (and might even start to use predicted torque control (basically where it starts to use the throttle blade to control torque instead of pulling timing)).
The bad part about this is that the module that controls the traction and launch control, the chassis control module, has no aftermarket options that I know of to recalibrate it. So even with HP Tuners or EFILive or anything like that, there's nothing you can do to fix this. Even with drag radials (Nitto NT555R2's), which can almost dead hook from a dead stop in the right temperatures and surface conditions, the launch control will still bog the same amount as it does with stock tires. It's like it completely ignores the wheel speed sensor feedback and just pulls the same amount of torque. It's a real shame that we can't fix it, because I feel like with the launch control optimized it could be made to work very well for actual 1/4 mile runs and launches. |
01-17-2022, 07:12 AM | #7 |
Not 100% sure it takes effect with launch control, but there is a minimum timing table that can be adjusted. If I recall, stock values allow negative timing during shifts and such. May be the same reduced power mode that affects launch control timing.
Of course adjusting that will affect other things too. But as others stated, theres nothing specific to launch control that can be tuned as far as i know.
01-17-2022, 08:52 AM | #8 |
It's torque management limiting throttle.
2016 NFG 1SS A8
01-17-2022, 09:16 AM | #9 | |
That explains why I did not detect any wheel spin before it bogged down. Just no response then the system fed some throttle. I went from 4.2 when operating correctly to to 4.7 0-60. When it works it's awesome though. |
01-17-2022, 12:00 PM | #10 | |
My thinking is, but like I said haven't tested it, is that the launch control TM is done mostly with the throttle (predicted TM), although you can definately hear the timing being pulled in parallel. I think even though I think the stabilitrac system and brake control module sources its min timing in a different way. So basically I think even if you max this min table out, I think stability systems can still pull timing. So I haven't confirmed this but I know stabilitrac still seems to work correctly even if you increase the min table, but again I haven't looked at the logs in detail to confirm. |
01-18-2022, 09:49 AM | #11 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Traction Control + Stabilitrak Switch to Track/Sport Mode then hit the TC button off 2 times in quick succession. This turns off TC and enables ESC Competitive mode. Give it another try. If it still bogs down which it shouldn't. Turn on Traction Control, then press and hold the Traction Control OFF Button for 10 seconds. This turns ALL nannies off. |
01-18-2022, 10:07 AM | #12 | |
Your first suggestion is how I do it but next time I will try holding down the TC button for 10 secs and see if that works. |
01-18-2022, 10:11 AM | #13 | |
The Bog down might be part of the Launch Control System as well. I usually brake torque my tires to certain RPM's and never really had an issue with engine bog downs. |
01-19-2022, 12:34 AM | #14 | |
Drives: Camaro Super Sport, Six on the Stik Join Date: Jul 2021
It bogs down when your rear wheels start to lose traction. Its modulating your throttle to eliminate the wheel spin. |
