01-13-2022, 05:42 PM | #1 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Rock Chip Protection
OK Guys,
If you track your car alot and even in daily driving one of the areas on our cars that take a beating is in FRONT of the rear wheels. You will see scratches and stone bruises in this area of the car typically. Now you can constantly repaint that area but that is a PITA. They dont really make mudflaps that go in FRONT of the rear wheels like say the old Pontaic TRANSAMS had either. So a solution I decided on was to WRAP the car with a GLOSS BLACK wrap that matched my paint and overlay THAT wrap with a very high quality XPEL PPF (paint protection film). Warning, this stuff is EXPENSIVE and cost about 90 dollars a yard and it takes a YARD of this XPEL to do both sides. In the picture, the wrap goes from the door seam BACK to the wheel well opening and the TOP of the piece is at the split line and the bottom goes about an inch UNDER the rocker panel. If you look CLOSELY at the bottom LEFT corner you will see where the wrap and PPF begin. The reason of course for using the XPEL PPF is that is is relatively THICK and should make it more rock resistant. I TRIED getting by with simply using the wrap material but it wasnt durable enough. Note that my paint is HIGHLY reflective so it may look dirty but it is not LOL.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
01-18-2022, 11:57 PM | #2 |
Drives: Chevrolet Camaro 1SS Join Date: May 2020
Mine came w PPF from factory but it’s worthless. Literally just a small patch that hardly protected anything. Before i installed new ZL1 rocker panels, i PPF that whole area myself. The material wasn’t too expensive. I got the vivvid 3M PPF 12”x5’ (about $28) and that was enough for both sides. Didn’t come out perfect but as long as it’s covered it’s all that matters.
