01-11-2022, 05:48 PM | #15 |
Just for clarity, I'm talking about the ring gasket at the outlet of the manifold
01-12-2022, 02:22 PM | #16 |
Drives: 2018 ZL1 Join Date: Jun 2020
Yes
should be two gaskets? One for the header to cat, and the other is the outlet flange end. Not sure if they are the same for a ZL1 and an SS or not... Difficult finding those numbers... |
01-19-2022, 12:41 PM | #17 | |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
12624939: ring gasket at manifold 21992620: flange gasket on passenger side
01-20-2022, 05:51 PM | #18 |
thanks
05-11-2022, 01:33 PM | #19 | |
05-11-2022, 01:44 PM | #20 | |
If the studs were rusted in, I prob would have had to take further steps to drop the exhaust.
05-11-2022, 03:32 PM | #21 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
Didn’t read all this but why not just plug into the OBD2 port and monitor the factory O2’s?? They make wireless plug ins up to a gauge or monitor and you can see and scroll through a ton more items then just AFr.
05-11-2022, 03:49 PM | #22 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Here is a photo of mine... Before I upgraded to a V-Band clamp... hope this helps...
Never received feedback if it was put in the best place but based on what i read, i think so....
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
05-11-2022, 03:52 PM | #23 |
Factory controllers only utilize narrowbands. 2020 c8 corvette were the first to get a wideband on gm stuff
05-11-2022, 03:54 PM | #24 | |
05-11-2022, 08:30 PM | #25 | |
05-11-2022, 09:39 PM | #26 | |
This is why we use a wideband sensor to monitor and/or adjust PE AFR.
2016 NFG 1SS A8
05-11-2022, 10:13 PM | #27 |
You’re shitting me??!! My 2013 Nissan used widebands and the models been the same since 2009!!
05-12-2022, 08:51 AM | #28 |
Nope...GM has never used Wideband sensors up until the C8 platform far as I know.
2016 NFG 1SS A8
Thread Tools | |
