12-27-2021, 01:48 PM | #1 |
Drives: 2021 Camaro ZL1, 1970 BOSS 302 Join Date: Dec 2020
Limited Edition Hennessey Exorcist
2018 CHEVROLET CAMARO ZL1 HENNESSEY EXORCIST, going on the auction block at Mecum. Just thought everyone would like to know!!
https://www.mecum.com/lots/FL0122-48...ource=hs_email |
12-27-2021, 01:56 PM | #2 |
Drives: 2021 Camaro LT1 Join Date: Oct 2020
quick, sell everything you own....
12-27-2021, 02:16 PM | #3 | |
Drives: 2019 ZL1 Join Date: Mar 2019
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
12-27-2021, 02:52 PM | #4 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
For what they charge for this car, at a minimum could at least put some nice (and wider) wheels and tires on it considering it can fit them and should need all the contact patch it can get.
They can also rotate the tow hook 90deg. Maybe this is the way it's intended and I'm use to seeing them vertical, but looks goofy being sideways.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
12-27-2021, 03:05 PM | #5 |
They have the most impressive facility that I've ever seen, and their prices reflect it.
'20 ZL1 1LE A10,
12-27-2021, 03:22 PM | #6 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Limited edition? Sure, that will help it sell but I wouldn't ever let them work on my car.
12-27-2021, 04:02 PM | #7 |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
12-27-2021, 04:50 PM | #8 |
Disagree. Perhaps not with everyone, but they worked on 550 cars in 2019 so they must be doing a lot right.
'20 ZL1 1LE A10,
12-27-2021, 04:55 PM | #9 |
Well, you are the only one defending them on this forum, and you are also a Hennessey customer.
12-27-2021, 05:54 PM | #10 | |
I doubt any other shop does 550 cars or anything close to that.
'20 ZL1 1LE A10,
12-27-2021, 05:55 PM | #11 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
I enjoy their videos.
12-27-2021, 05:59 PM | #12 |
Drives: ZL1 1LE on order Join Date: Nov 2021
What’s the real world cost of having a reputable shop do that work to a brand new ZL1?
Just trying to see how far off the mark it is for having the “Hennessy” name. (I’m in the camp of Hennessy sucks also. I still remember the shady viper days) Just because someone is still in business and does volume doesn’t mean they’re honest/good etc. Lots of deceitful crooks out there that are still in business. It always catches up to them at some point. |
12-27-2021, 06:08 PM | #13 | |
I heard that they were bad with holding onto customer cars for longer than they should've, and that they were using money from future orders to pay for current customer builds (essentially a pyramid scheme). I've heard that Jalopnik isn't great journalism, but this isn't the only publication that I've read about Hennessey issues. I can't remember if it was Car & Driver or Motor Trend, but they also listed the issues with Hennessey. I'll steer clear for now as where there's smoke, there's usually fire. https://jalopnik.com/ex-employees-sa...-ev-1778134112 |
12-27-2021, 07:22 PM | #14 | |
They picked up my car and two weeks later it was in my driveway. I've had zero issues with the work they did.
But you can save a few bucks by calling your local Mom and Pop shop. Quote:
'20 ZL1 1LE A10,
