12-22-2021, 01:11 PM | #1 |
Drives: 2017 1ss 1le HBM Join Date: Jun 2020
BMR Rear Toe Links
Just got back from getting an alignment. The shop says when they turn the toe links when tight the rear toe changes from +.15 degrees to +.09 degrees which is excessive. These links are maybe 8 months old or so. Any thoughts on this? Anyone else experience this and is this to be expected with the solid end links? Should I look at replacing with different units?
I have used this shop many times and trust their diagnosis. |
12-22-2021, 05:45 PM | #2 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I've seen some continuous issues with BMR roll bar mounts and such. I'd check out SPL.
12-23-2021, 01:35 AM | #3 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
The shop I use gets it close with the links, tightens the jamb nuts down, and then does the final adjustment with the cam bolts. Thats another thing, with the BMR supplied hardware, there was slop so they used the factory cam bolts.
12-23-2021, 08:14 AM | #4 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Matt Miller
2020 SS 1LE |
12-23-2021, 10:48 AM | #5 | |
12-23-2021, 11:43 AM | #6 | |
Not sure I do either which is why I am asking. With the jamb nuts all tight after adjustment they said if they turn the link it will induce toe change. One of the selling points of these is that it reduces the toe change inherent in the rubber bushings on the stock links. They deal with many race cars and told me that the spherical ends might not be perfectly round or ?? but that it should not change when the jamb nuts are tight and it does. Does not sound like anyone else has come across this then. Last edited by nprario; 12-23-2021 at 02:17 PM. |
12-23-2021, 03:56 PM | #7 | |
Matt Miller
2020 SS 1LE |
12-23-2021, 11:26 PM | #8 |
Yea, bearing runout is what they were suggesting. I honestly can't see it either but was just wondering if it was a thing that anyone else had experienced.
12-24-2021, 01:29 AM | #9 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Alignment settings SHOULD NOT change except possibly due to wear and tear.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
12-24-2021, 08:15 AM | #10 |
I'm 100% sure that neither BMR nor SPL are making their own spherical bearings. Those are almost certainly off-the-shelf parts from a company like Aurora. You should be able to look at them see and brand and part number. So it would be easy enough to get replacements, if needed.
Also, I seriously doubt anyone else has ever tried the "twist test" that the OP's shop is doing. For all we know, every spherical bearing toe link does the same thing due to some geometry situation. I'm not sure. If the bearings have slop, that's somewhat understandable and they need to be replaced. You can easily check for slop by feel and eyesight. I guess the way they could have runout would be if the bolt holes through their centers weren't actually centered. But unless these were sourced from some really low-quality factory in China, I can't imagine that either. OP, maybe someone here has a good way to measure for runout, but I can't think of one. I'd take a close look at the bearings and maybe use some calipers to try to verify that they are concentric. Figure out what brand and part number they are and let us know if you can. Worst case is you buy some new rod ends and put them back in. I had to replace some on a my C4 once I seem to recall that the Aurora Teflon-lined rod ends were less than $15/ea.
Matt Miller
2020 SS 1LE |
12-24-2021, 02:46 PM | #11 |
Good information. Thanks Matt.
12-27-2021, 07:57 PM | #12 |
I'll ask the shop I use when I can but I think they were saying there's a slight change when the jamb nuts are tightened. Maybe its because of thread slop?
12-28-2021, 08:33 AM | #13 |
If that's the case, I can easily believe that. That would make more sense.
Matt Miller
2020 SS 1LE |
12-28-2021, 09:15 AM | #14 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Thread slop gets my vote. When adjusting valve lash on mechanical, overhead cam car and bike engines, you have to set the lash a few mils tighter in order to achieve the proper lash once the jamb nuts are tightened.
Baby Blue
