12-20-2021, 06:01 PM | #1 |
IMPACT FOR LUGNUTS AT TRACK
anybody have a impact that they recommend for track use? my gf works at home depot and uses ryobi so i saw this one but wasnt sure if it was enough torque? thanks
https://www.homedepot.com/p/RYOBI-ON...61K1/314857613 https://www.homedepot.com/b/RYOBI/1-...&sortorder=asc
12-20-2021, 06:44 PM | #2 |
I’ve got the Milwaukee version as I like that they have 3 zillion tools that all use the same battery packs, but the Ryobi one you posted should be fine too.
12-20-2021, 06:50 PM | #3 |
haha yea my gf has ryobi thats why she wants to get me one cause she has a shit ton of batterys
12-20-2021, 07:40 PM | #4 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
I use a Bosch version. It’s only rated to 95 lb-ft but that’s plenty. I use a torque wrench to tighten and loosen anyway, and only use the impact to quickly do the first or last 75% of the work
12-21-2021, 05:58 AM | #5 |
I use Milwaukee M12 FUEL STUBBY 1/2" IMPACT WRENCH KIT with 4.0 battery. Recently upgraded to a 6.0 battery. Works great for taking them off and putting them on quickly without over torqueing. Use without an extension for best results. Also use racing type lugnuts.
12-21-2021, 06:58 AM | #6 | |
Drives: Camaro 1ss Join Date: Nov 2019
If going with Ryobi, Get this one. ( https://www.homedepot.com/p/RYOBI-ON...oduct-overview ) has 600ftlbs of breakaway trq... Please use a trq wrench though when reinstalling lugnuts.
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
12-21-2021, 07:08 AM | #7 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
I got into the Ridgid ecosystem due to their lifetime battery warranty. I've used their 1/2" impact for almost two years without issue.
https://www.homedepot.com/p/RIDGID-1...SB2N/316087389
12-21-2021, 08:15 AM | #8 | |
Drives: broken Join Date: Aug 2009
I use the equivalent Milwaukee M18 mid-torque with 600ft-lbs breakaway and wouldn't use anything less powerful. With the 140 ft-lbs spec, the lower torque models will often take their time at breaking the lugs...and be unable to often enough to be annoying. The mid-torque guns will take them off like butter every time until the battery is nearly dead.
clyde
Team WTF?! what are you gonna do? :dunno: |
12-21-2021, 08:50 AM | #9 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
I had that but because of the lack of torque it was a little hard to get the camaro lugs off. went all out and got the Milwaukee 18v. works like a charm zero issues.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
12-21-2021, 08:58 AM | #10 |
Who Needs to KNOW?
I have dewalt 20V version, its heavy, LOUD and does not always break them loose, breaker bar for that and then gun to zip on or off for torque wrench.
ing for grip.
12-21-2021, 10:41 AM | #11 | |
Thanks tim ill let me my gf aka santa know haha
12-21-2021, 10:50 AM | #12 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I tried the $99 Kobalt 1/2 drive impact from Lowe's that was advertised as having up to 200 ft lbs of torque on the box since I already had a compatible battery but it took a long time to break the lug nuts loose and sometimes couldn't do it at all so I returned it and got this $100 greenworks impact with battery and charger from Amazon which works well so far. The middle setting is a little under 140 ft lbs so I am going to buy a torque stick to use with the highest speed setting to avoid needing to manually use my torque wrench.
https://www.amazon.com/gp/aw/d/B09DCGQTYB https://www.amazon.com/gp/aw/d/B079P9GBRL/ |
12-21-2021, 11:06 AM | #13 | |
Breaking the top bolt loose also required a long breaker bar underneath the car with it on a lift since the plug in electric impact that I bought with 1050 ft lbs of breakaway force wasn't enough with the u joint, even after heating the bolt with a handheld propane torch for a few minutes. All of that to say that having a larger impact may not actually be beneficial in practice. |
12-21-2021, 11:09 AM | #14 |
im literally just going to be using it for lugnuts probably nothing really else my gf has like 10 + batteries already so thats why i want to stick with ryobi
