12-19-2021, 07:14 PM | #1 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
Cam lift
Wondering how many have a cam in the 630 lift range and how they hold up. Thinking of the ss1 gpi but man I don't want to drop a valve.
this is a daily that Im looking to do 100000 miles. Iv heard that as long as I do springs every 25000 or so should be good Im looking for real world results Thanks Guys and gals. |
12-19-2021, 07:23 PM | #2 |
What heads do you plan on using?
2016 NFG 1SS A8
12-19-2021, 09:09 PM | #3 |
Stock and Im procharged at 10 psi
12-19-2021, 09:47 PM | #4 |
Drives: 2018 1SS 1LE Join Date: Jul 2012
I’m at .646 lift, Livernois stage two heads, Procharger-8lbs of boost and I love mine. Drivability is impressive. As far as how they hold up: I don’t have many miles yet so I can’t speak to that, although no issues thus far. I can tell you it’s fun! Good luck!
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
12-20-2021, 09:08 AM | #5 |
Depending on the setup I would have the valve seats and guides redone or just go with a aftermarket casting. LT1 heads are prone to seat failure. Some get away with it others don't. Most that have don't have many miles on their setup. There is a post right now in the bolt-on section of a 416 build that dropped a valve and trashed the motor. Plenty of info out there on this topic...TSP put up a disclaimer a year or so ago on their site about it. https://www.texas-speed.com/p-4407-p...g-service.aspx
Not saying it can't be done but I wouldn't run a .650 lift cam and 150+ lb dual springs. If you decide to go for it then I would have cam motion spec out a very mild lobe lower lift cam(.600) with some lower seat pressure(130) springs. Call them!
2016 NFG 1SS A8
12-20-2021, 07:36 PM | #6 | |
12-20-2021, 08:14 PM | #7 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
.645"/.635" El-7 TSP Cam- just got it in last week of Sept. U have address the heads for sure. I did the smith brothers trunion kit, 660 double springs, LS7 lifters, shaved heads, BTR push rods, and port in and out plus hand ported by Katech. I also did brass stems and a full valve job. Katech said my set up is good for 50,000 miles. Hopefully no problems in the future.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 12-20-2021 at 08:33 PM. |
12-21-2021, 10:59 AM | #8 |
What about the hot cam setup if never going to update to lt4 fuel. Comes with heads and cam ect. How would it work with a procharger, and 10 speed auto. I would not want a bunch of shake,surge at like a red light
Im double down on meth. I have done away with any push connectors including the fuse holder. Also if the controller loses power for any reason my afr gauge goes off Last edited by Kerry; 12-21-2021 at 12:38 PM. |
12-21-2021, 02:15 PM | #9 | |
I did the hot cam in my 2016 SS, my advice is don't do the hot cam. Its a dog and does not add much power. It sounds good and that's all it does.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
12-21-2021, 05:50 PM | #10 |
I believe Pray ripped the Hot Cam apart on this board a number of years back. He shredded it, chapter and verse if memory serves.
