12-10-2021, 11:51 AM | #1 |
Drives: Yes Join Date: May 2009
Borla 11922 Camaro SS 2016-2019 Axle-Back Exhaust S-Type
Product Description Borla designs their exhaust products to ease the stranglehold your stock exhaust system has on your vehicle's engine. Borla's patented technology opens the way for escaping gases, and maximum exhaust flow equals improved performance. This translates into more power and torque when you plant your foot, along with increased fuel economy at cruising speeds. Borla builds its exhaust systems from aircraft-grade T-304 stainless steel, so they're lighter, stronger, and last far longer than factory exhausts - all with easy bolt-on installation. Extensive research determines which tube size will get the most performance from your car or truck. Smooth mandrel bends and efficient design give the exhaust a mellow rumble while keeping most of the sound behind the exhaust tips. This means you won't get unwanted droning noises in the cockpit while cruising. Every Borla exhaust system gives you precision fit with motorsport-inspired styling, all backed by a million-mile warranty against defects in material or workmanship. This system is for vehicles that come from the factory with single tips are not equipped with NPP (dual mode exhaust). Application 2016 2017 2018 Chevrolet Camaro SS 6.2L V8 without NPP (dual mode exhaust) |
12-15-2021, 11:56 AM | #2 |
Thank You for your orders
Use SAVE4NOW to claim your discount |
01-07-2022, 12:42 PM | #3 |
05-20-2022, 02:59 PM | #4 |
Thank You for shopping at https://www.pfyc.com/borla-11922-cam...st-s-type.html
08-10-2022, 12:35 PM | #5 |
08-10-2022, 06:17 PM | #6 |
Drives: Chevy Camaro Join Date: Apr 2020
Does Borla make a twin tipped s muffler set, without the npp valve, that can be used to convert a non npp car over to quad tips?
09-02-2022, 03:01 PM | #7 | |
