11-13-2021, 03:13 PM | #1 |
Drives: 2020 ss Join Date: Nov 2019
20 ss A10 issue?
Anyone have issues with the a10? I have heads ,cam ect along with a tuned tcm. Now the trans seems to be kind of reving then slipping into certian gears, when it does the slipping feeling ,then give it more throttle is seems make the trans vibrate (maybe shutter?) But not downshift. Also is there any other auto trans I can swap out ?
2020 Camaro SS
Heads,cam,hi-ram,hhp tcm Last edited by Purplt1; 11-13-2021 at 04:16 PM. |
11-14-2021, 10:47 AM | #2 |
Stock converter?
2016 NFG 1SS A8
11-14-2021, 08:43 PM | #3 |
Drives: 2019 Camaro SS Join Date: Nov 2020
I noticed mine does something similar when it's cold out going into 3/4. 99% sure it's condensation in the fluid since these trans operate at such cold temps. I'm going to have mine changed before spring and see what that does.
11-16-2021, 05:41 PM | #4 |
Yes stock converter. I think the issue is fixed now. I switch tuners and now is alot better but we're still working it.
2020 Camaro SS
Heads,cam,hi-ram,hhp tcm |
11-23-2021, 10:51 AM | #5 |
Petro-sexual
Good Lord. Having to change tuners stinks... Good to see you're on the right track now.
