10-19-2021, 05:16 PM | #15 |
You don't really need a larger blower then a 1500sl unless you plan on going north of 900whp. Again it's comparable to Prochargers D1.
The LT4 blower isn't making 1k whp...just because 1 shop did it with the kitchen sink thrown at it doesn't mean that shop would send customers cars out that way. They even said they themselves. The ECS might make less torque because it's not spinning hard since it's quite a bit bigger head unit then a P1 Procharger.
2016 NFG 1SS A8
10-19-2021, 05:41 PM | #16 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
You are right, most cases I see run either the entry 7 lbs set up or they change cog and belt to set it to the 10 lbs range with lt4 fueling. I haven't seen an ecs system on the full tilt cog set up, but I'd like to, they claim 15 lbs. |
10-19-2021, 09:51 PM | #17 |
Drives: 2020 LT1 Join Date: Dec 2019
Wnta1ss. Thanks for sharing your experience. I believe they say stock kit on stock car was 550 wheel. You going high 10s sounds great at that power level. I too am curious why you dont run their kit anymore.
If it was trouble free, id assume running around with 550-650 on LT4 fuel and a low side would be good to go for a while. If it pops or one is ready for the shortblock, a pulley change and port injection would max out the 1500 shy of 900, be efficient and responsive. I am curious if belt slip becomes an issue at higher blower speeds. Not at the cogged pulleys obviously, but the serp. One driving it. |
10-20-2021, 02:43 AM | #18 | |
10-20-2021, 06:33 AM | #19 |
Kit was working alright when I removed it. Power delivery is that power builds with rpm, because boost is low at 3000rpm then continues to rise with rpm. Reason for removal was to make long runs. I learned after my purchase that LT1s are built with tight to really tight ring gaps, making them sensitive to heat. Pushing them too much can break pistons. Not all engines have the same gaps (one guy .015, another guy .007) so it's really a crapshoot how far you can push yours. I took the risk on a 1/4 mile, but chose not to risk going WOT for a longer distance with the blower on my stock engine.
10-20-2021, 06:42 AM | #20 | |
Jackshaft drive is the question on how far can this be pushed. Guy in Georgia with cam/pistons/headers/methanol/e85 turned his up to 829hp as I recall. Vortech now sells a 10-rib dedicated drive system which should be able to max out the 1500SL, priced little over a grand I think. |
10-25-2021, 09:56 PM | #21 |
Drives: 2017 camaro ss 1le Join Date: Oct 2021
I am planning on going with the ecs kit, drop ins, stage 2 blower cam and ported heads with a clutch over the winter. Hoping 800-850
Dsx aux pump lt4 pump lt4 injectors on 93 |
10-29-2021, 09:21 PM | #22 |
Where are you getting it tuned? Speed Inc tunes mine, and I have the lt4 pump and injectors ready to go. They told me to get the DSX as well, but said i wont be able to be on E anymore, even with an 8 pound pulley combo. Can that fuel combo support 800+ on 93? If so, and E is 30+% more volume, shouldnt it support mid 600s? (My target)
10-30-2021, 08:34 AM | #23 | |
10-30-2021, 11:04 AM | #24 | |
I did a back to back comparison between my 3.5 and 3.25 pulley. With my 3.25 pulley I am seeing 11psi peak when it's 50 degrees outside. With E40 fuel and 18 degrees timing the car traps about 1-1.5 mph higher in the 1/8th vs the 3.5 pulley(9psi peak), E65 fuel, and 20 degrees timing.
2016 NFG 1SS A8
10-30-2021, 01:35 PM | #25 | |
Mixing to E50 here and it was worth 90 HP over 93 octane at the same boost level on my build. If I had more E with me at the dyno I would have tried E65-70 or more. But to Kings point, you don’t need full E to see some fantastic benefits. And mixing to ~E50 is so easy.
10-31-2021, 03:58 PM | #26 | |
Drives: 2016 1SS A8 Camaro with MRC and NPP Join Date: Oct 2016
Install is strait forward and its nice to not mess with the stock balancer big plus .... long term durability has been great so far holding up well. Honestly I like the simple design of this kit for what it is (low price) very well thought out and robust with a Large IC (system runs very cool temps). As far as power on low boost that system is very efficient (1500SL is a great headunit as is the Procharger units ) with room to grow (even though not 10 rib it has short belt length with good wrap and then the Cog setup) I'm making great power on 5.5 lbs only and trapping 129 in the 10s 1/4 mile (#30 on 1/4 mile fast list#5) which isn't too bad. I plan on adding a cam setup and more boost in the future which should be fun with this kit and provide plenty of ceiling. On a Stock LT1 you'll run out of piston usually before you run out of boost potential with this kit but around 15 psi is doable.... if you have bigger dreams then yeah the 10 rib Ysi setup would be sick. Another thing I never really see mentioned with this kit (because most focus on outright power) vs it's competitors is the quick response of the kit because of its unique drive setup. Between the short belt and Cog setup it makes it very snappy feeling. And as someone who likes to take some turns with their 6th gen this is something I appreciate. If you don't need to run a ton of boost with a big cube engine this is just a great kit. -Jon
2016 HB Camaro 1SS A8 with MRC and NPP 398rwhp/389tq stock #s(11.84 @ 117 DR only, ECS boost 550rwhp/510tq (dynapack #s) , same boost + AEM water/meth + ARH Headers/mids 600 rwhp+ (dynojet #s) TTP)10.8 @ 129.
2020 Ford Explorer 2003 SVT Cobra Coupe (just your average KB Terminator Cobra). 2013 Focus ST (e30 Tuned). 2004 Dodge 3500 Cummins Dually 6 spd manual (tow rig). 1997 Jeep Cherokee (Lifted and Locked XJ off-road rig). Last edited by RageWorx; 10-31-2021 at 04:09 PM. |
10-31-2021, 04:16 PM | #27 |
So with that kit it builds boost quicker then the Procharger? That means you really may not need a stall converter to launch the car as you normally do with the P1 or D1 for quicker times. That's a big savings for most who don't care about make big HP.
10-31-2021, 04:53 PM | #28 | |
Drives: '18 SS 1LE Join Date: Jun 2021
