![]() Drives: 2017 Chevy Camaro Join Date: Jul 2021
2017 Camaro 2SS, P50D Cold Start/Rough Idle code.
It appears this error code is common so the dealership just replaced all fuel injectors!
When I picked up the vehicle it didn't want to start (cranked for quite a while before turning over). It finally started but when I drove there was a very strong fuel smell. When I turned it off it started again after a 15 minute sit, but when I parked for more than an hour and tried to restart I had the same (cranked for quite a while before turning over) issue. What is the issue?...Leaking fuel injector? Bad fuel injector install/replacement? Why is the fuel drained or not primed after waiting for an hour? Runs completely fine once started and running??? |
![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
Based on the description of your scenario I sure would be hesitant on continuing to drive if you smell a strong odor of fuel. There’s a lot of pressure going to the injectors on the high pressure side if you have an external leak at a hard line. Your leak could be on the low pressure side.
I’d really consider having it towed back to the dealership and let them fix the leak.
#3 | |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
2017 Chevy Camaro 2SS A8 Kong ported Whipple 8.00/3.00, Mast Black Label heads, Fore triple in-tank pumps, 229/245 cam, Rotofab Big Gulp, 112mm TB, forged pistons & rods, LPE +52% injectors, LPE BB HPFP, AWE CB, GForce DS & axles, 2” coated headers, MM Wild CC, everything BMR makes, OEM 1LE wheels (street), Forgestar D5 bead locks (track). 927 WHP/917 WTQ, 9.65@146
2021 Ford Expedition Limited 4WD (daily driver) 2018 Alfa Romeo Giulia Ti Sport Q4 (hers) |
Thread Tools | |
