11-26-2020, 10:15 PM | #15 |
Drives: 2018 Chevrolet Camaro ZL1 Join Date: Jun 2018
I realize this is an old thread, but:
How do I see the settings for the NPP valves? My ECU and TCM have been tuned by a shop, using their hpTuner interface. When I connect my interface to the vehicle, and "read entire" for ECU, TCM, and CCM, it reads the ECU, TCM, and then fails to read the CCM. However, an error message stating that "the tune file is being supplied with a stock file since the control module is not readable". Comes up. When I then look at the file, I am not seeing any settings under system regarding exhaust valves. Note the CCM has not been licensed, but from my understanding, I won't license it until I try to flash a new file to the module. Can anyone shed light on this? |
11-26-2020, 10:57 PM | #16 | |
Not sure why your HPT says it wants to read the central control module and not the FSCM when you select "read entire", it should definitely be able to read everything, including the FSCM, whether or not you have credits. Do you have the MPVI2 interface or the older one?
11-26-2020, 11:19 PM | #17 | |
I definitely don't have those active exhaust options under system-> general. In fact, I have alternator and Starter relay, but not even the same options as you are showing under alternator. |
11-26-2020, 11:57 PM | #18 |
Very weird. In case it helps, see the tune details for the result of my "read entire" operation.
I'm out of my depth here, but I can think of three things: 1) your older MPVI1 interface has some compatibility issue with this module, 2) your HP Tuners version may not support these parameters—but then you say you have the latest (I'm using 4.4.4, which is not the latest, and reading the tune worked fine), or 3) your tuner did something to the calibration that makes reading the FSCM impossible. Hopefully someone near you can help you out with an MPVI2 to at least test the first hypothesis, this would be the simplest initial thing to check.
11-27-2020, 07:37 AM | #19 | |
11-27-2020, 09:58 AM | #20 | |
11-27-2020, 11:58 AM | #21 | |
arpad_m, what do the dates / numbers in your signature represent? Thanks for your assistance. |
11-27-2020, 01:43 PM | #22 | |
My sig reflects the timeline and status code changes for my order I placed for this SS in 2018.
11-29-2020, 09:25 AM | #23 | |
No problem and thanks again! I was able to use some info KingLT1 previously posted (thanks!) to get my CCM tuned to keep valves where I want them. And for those wondering, 18+ ZL1 requires 3 credits ($150) to tune the CCM (ZL1 has CCM whereas SS has FSCM). |
12-04-2021, 09:13 PM | #24 |
Thread revival. Having a similar issue trying to read the C304a CCM on my Brother's 2019 ZL1 A10. It just fails on read attempt then says:
"Controller unlocker: web service- response pending, try again in 15min." Perhaps I need to try during HPtuners regular business hours? I asked on HPt and received a response from Bill to open a support ticket which requires jumping through a bunch of hoops. Hoping somebody might have a quick answer? Thx
2016 NFG 1SS A8
12-05-2021, 04:34 AM | #25 | |
12-05-2021, 05:14 AM | #26 | |
12-05-2021, 09:05 AM | #27 | |
Ok cool so I am not the only one this is happening too. Thanks!
2016 NFG 1SS A8
09-13-2022, 07:51 PM | #28 |
Just wanted to update. The issue was HPt didn't have it supported yet. I had to file a support ticket then get it added. Once they did that I was able to connect to the internet and license the controller.
2016 NFG 1SS A8
