Old 03-19-2017, 09:49 PM   #15
kparker
kparker's Avatar
Drives: 2017 SS 1LE Artic Blue
Originally Posted by Summit1le1ss View Post
look under your tire cover and lift up that foam holder for the air pump. I saw something that looked like an amp.
Definitely not under the tire cover for SS 1LE.
https://1drv.ms/i/s!AkO3V-mzK1jekIkIjSnEAWjiJYSbiw
SS 1LE PDR Artic Blue (VBWZZJ )
ordered - 1/17/2017
1100 - 1/27/2017
3100 - 2/06/2017 TPW 2/27
3400 - 2/21/2017 TPW 2/27
4200 - 2/28/2017 Built 190751
delivered - 3/5/2017
kparker is offline   Reply With Quote
Old 03-19-2017, 09:54 PM   #16
CrashSS
PWRTR1P
CrashSS's Avatar
Drives: 2017 SS 1LE
I want to do full interior speaker swaps and maybe subs later, I hope to see someone do this soon...im a giant snob about music quality particularly since rock is my forte, and I like it LOUD.
2017 Mosiac Black Metallic Camaro 1LE
CrashSS is offline   Reply With Quote
Old 04-04-2017, 02:15 PM   #17
prs0314
Drives: 2017 1LE
Originally Posted by WhyUMad1LE View Post
Thanks, I will check that out.
Any luck finding it? I currently have mine apart and can't...
prs0314 is offline   Reply With Quote
Old 04-05-2017, 03:17 AM   #18
WhyUMad1LE
Drives: 17 SS 1LE
Unfortunately no.. you checked behind the rear passenger speaker panel?
Old 04-22-2017, 04:57 PM   #19
2010IOM
2010IOM's Avatar
Drives: 2017 1SS1LE Hyper Blue
Soooo it's definitely not behind the rear passenger seat speaker panel. Anybody actually lay their eyes on the 1LE amp yet??
2010IOM is offline   Reply With Quote
Old 07-07-2017, 08:12 PM   #20
IrishCoffee
IrishCoffee's Avatar
Drives: 17 SS 1LE
I've seen a few threads mentioning this, but am just curious if anyone has actually located the amp in a 1LE yet.
IrishCoffee is offline   Reply With Quote
Old 07-07-2017, 08:43 PM   #21
davef
Drives: 2017 SS 1LE Garnet Red
It is not behind the passenger rear panel as I first thought. That was incorrectly told to another member by the parts department at his local dealer. As far as I know, no one has found a separate amp.
davef is offline   Reply With Quote
Old 07-07-2017, 08:56 PM   #22
formoutofchaos
Drives: Camaro 2017 1LE
I had a system installed the mylink corrupts the signal it's not worth it it won't upgrade the sound I had them put back in
formoutofchaos is offline   Reply With Quote
Old 07-07-2017, 09:28 PM   #23
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I had a service writer look it up for me. The SS 1LE specifically doesn't have a separate amp, like we deduced. It just has the 8" display and the "receiver", which is located fore of the glove box. Here's a drawing I was given, the perspective is looking from the front towards the aft of the car.
I was also told there isn't the ANC in the SS 1LE, due to the lack of a normal amplifier, however the wire colors going to the speakers is still the Blue+ & Brown/Blue-, and Yellow+ & Yellow/Black- for the front speakers. Sourcing from the rear speakers is an unknown and might not be full-range. Use at your own risk obviously.
Based on my searching in my own car it appears the easiest way to tap into the front channel high-level signal is at the bulkhead connectors behind the footwell kick-panel trim. It's not easy to get to, and you'll have to cut factory wires to splice in an external amplifier.
I hope this helps.
Old 07-07-2017, 10:53 PM   #24
formoutofchaos
Doesn't work I tried w a 3500 install signal does not handle amp amd speakers well ended up putting stock back
http://www.camaro6.com/forums/showth...04#post9800204
Old 07-07-2017, 11:48 PM   #25
SlickZL1
SlickZL1's Avatar
Drives: 2017 SS 1LE
I just finish swapping mine to a full kenwood excelon setup, using an LC7i to convert the factory stereo signals and ran all new wire from the dash to the trunk to hook up the lc7i and a Kenwood 900-5, 5ch amp. Kenwood components in the doors and GM specific oversized 6 1/4 for the rears with a 12" JL sub in a sealed enclosure. Now it hits hard, and the highs are crisp, nothing crazy, but for under $1k, it's perfect for me.
SlickZL1 is offline   Reply With Quote
Old 07-08-2017, 12:47 AM   #26
Cldgin2
Cldgin2's Avatar
Drives: 2017 1LE SS
Did you have to cut wires, or was this some sort of harness converter?
If I worded this wrong bear with me, not very technical on this and simply want to convey imfo to my local stereo shop
'If one day the speed kills me, don't cry. Because I was smiling.' - Paul Walker
Cldgin2 is offline   Reply With Quote
Old 07-08-2017, 10:31 AM   #27
IrishCoffee
Drives: 17 SS 1LE
I hope this helps.
Really good info here. Between this and the brake pads you are doing my homework for me. Thanks!
Does the 1LE also have the sound from the engine added to the signal? Seems like it would be difficult to disable if the only way to grab signal is at the speaker level.
Old 07-08-2017, 04:25 PM   #28
SlickZL1
SlickZL1's Avatar
Drives: 2017 SS 1LE
The SS 1LE has no external amp, no rear deck speakers and no center dash speaker. That means there are no readily accessible speaker inputs in the trunk, and no premade adapters fit this setup.
I spliced into main stereo wiring in the dash, then ran new wire to the trunk to connect the audio control LC7i, it converts and creates rca outputs for the system amp to power the speakers. The factory speaker wiring was disconnected from the speakers and new wiring was run from the trunk to each location. I also added the acr-1 remote bass knob to the console from the LC7i.
I hope that helps.
