03-28-2018, 04:53 PM | #57 |
Drives: 2018 ZL1 A10/2018 GT350R #JR603 Join Date: Jan 2017
Yes. What do they say about oil that makes contact with the internal engine?
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
03-28-2018, 07:23 PM | #58 |
Sarcasm loading --------
I changed oil at 600 miles and I checked my oil today (about to do an oil change) at 4k miles and it did not use any.
unfortunately the joke was on me; the car is too low to get on my 2 post lift.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
03-28-2018, 09:04 PM | #59 |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
If you feel like the OLM is miscalculating or not representing the true degradation state of your oil you have options, you know.
- You can just reset the OLM yourself without changing the oil. - You could change oil without resetting the OLM. - You could also change oil when you believe it needs to be changed and reset the system at that time. My first oil change at about 200 miles I didn't even look at the Oil Life guage - didn't know it existed. I just wanted to be sure any metal filings or assembly debris were cleaned out. When I changed oil the second time at about 600 miles, OLM it said I still had 80% life left. I knew that it needed to be changed so I went ahead and changed oil and filter myself but left the meter alone. The first-catch sample I took proved me right. It was dark with a minor amount of suspended fine metalic particles, which is to be expected on a new motor. That's when I replaced the plain drain plug with a magnetic one designed for the Corvette C7. Other engine oil changes were at 1200, 2500, 3600, and 4500. The 1200 and 4500 changes were my 2 free GM oil changes. They will automatically reset your life meter at the dealer service. I'll do another oil change myself this week when I expect to trip 6000 miles on my ODO. I'll reset the meter myself. Why change my oil so often? Mostly for peace of mind... Most of my miles so far have been drag racing or travelling to and from tracks. During break-in I changed it more often. Since then it's been about every 1000 miles. This time I let it go a little farther (1500 miles) to see how it looks. If it's darker or smells older I'll go back to fewer miles. I figure it's cheap insurance to minimize engine wear and keep it clean inside. --Cal Last edited by cwebster; 03-28-2018 at 09:15 PM. |
03-28-2018, 09:14 PM | #60 | |
Cal
If you can't borrow a drive-on or adjustable 2-post, I guess you could use a floor jack to put the car up on jack stands. |
03-29-2018, 09:44 AM | #61 | |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
03-29-2018, 01:27 PM | #62 | |
the car has an aluminum brace underneath, and it blocks any places where you would be able to put a jack, and there is nothign under the nose of the car to jack on to lift it up to put extensions on the arm ends to clear the ground effects. Ive never had this problem before... I guess im SOL.
07-08-2018, 04:46 PM | #63 |
Update:
Since the oil change at 4437 miles, I have really racked up the miles(LOL) and have gone 560+ miles. I have almost babied this thing, highway miles at 65. Since the original post I went back and rechecked and I was a little off on the miles. It was 1.75 quarts for 2700 miles or a qt for around 1500 miles. So the oil has not moved anything and it should have burned at least a third of a qt. So just to show that high RPM's, means high oil consumption along with high gas consumption.
Current ride
08-13-2018, 11:55 AM | #64 |
Drives: 2022 2SS A10 NPP MRC Red Hot Join Date: Aug 2016
Last oil change at 21.5k miles, Edge 5w30 D1 in the crank, usage has improved to a quart every 3300 miles. Better result since the last time I posted here (qt every 2.5k mi).
Using Edge 5w30 again, although the formula has changed to meet the D1G2 spec. Might try a 5w40 next time..... |
08-13-2018, 05:05 PM | #65 |
Drives: 2018 Camaro ZL1 Garnet Red Join Date: Jul 2018
Just did my 500 mile break-in oil change. Changed to 0w40 and the car hadn't consumed any at the time of the change.
Beating on it regularly and will check again at 1500. |
08-13-2018, 05:38 PM | #66 |
Thank you Al Oppenheiser!
08-14-2018, 12:49 PM | #67 |
I changed first @ 1,000 and not since. I drag race often and so far no noticeable loss of oil at 4,000+. Going to the 0 weight next if I can find it.
08-14-2018, 01:00 PM | #68 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Did 500, 1500,
then every 5000 miles. 10 qt of Mobil1 5w30 + PF64. Added magnetic plug on the first one. Consumption ~ zero. Use race ramp with extension for low clearance. |
08-14-2018, 01:20 PM | #69 |
Drives: Rally Green 2020 ZL1 1LE A10 Join Date: Jul 2018
Ive done the 2 recommended oil changes at 500 and 1500 with 5w 30 per the cap and manual, and am now at 2500 miles and no oil use so far.
12-08-2018, 05:22 AM | #70 |
Drives: 17 ZL1 Join Date: Mar 2017
I'm resurrecting an oil thread to see if everyone is willing to update us on their oil consumption after putting several thousand miles on their LT4.
2017 ZL1 M6 10K Miles Moderate spirited driving Usage 1/2 qt 3K miles
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
