01-21-2016, 11:50 AM | #1 |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
Catch Can Routing Diagram for Turbo
I am preparing for my single turbo build and I have been reading a lot of different threads about how people have routed their catch cans, which appear different for supercharger versus turbo. I have located a diagram on the LS1tech website that matches what I believe I need. I just need someone to chime in if this is wrong, or confirm it looks accurate. Some run a separate catch can for the breather on the valve cover - any thoughts on that?
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
01-21-2016, 12:26 PM | #2 |
Drives: 2006 Z06 Join Date: Oct 2010
Nope. I wouldn't do it like that.
Get a mighty mouse can and talk to dave. You probably want a dual input can. Having the turbo suck from the valve cover is just going to draw a ton of oil/crap into the turbo/intake system making the catchcan almost useless. You want valve covers and valley plate going to the catchcan.
Nick
Corvette Z06 -1200ish rwhp |
01-21-2016, 01:04 PM | #3 |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
Here is a PCV routing document from MightMouse and while it was specifically designed for me but it may help. I've had zero problems with my MM single PCV setup.
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
01-21-2016, 07:35 PM | #4 |
Drives: '10 Black/IOM Camaro SS/RS Join Date: Mar 2010
I run my turbo car with MM can just like the diagram drawn by Sakudog. I have also run the diagram you posted from ls1tech. No problem either way.
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
01-22-2016, 12:02 AM | #5 | |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
01-22-2016, 06:31 AM | #6 | ||||
01-22-2016, 07:09 AM | #7 |
Drives: 2013 Camaro SS 1LE Join Date: Oct 2014
i have mighy mouse catch can. i used his diagram when i had turbo and it worked fine. the diagram is on this page.
http://www.mightymousesolutions.com/#!mm-black/ca5m |
01-22-2016, 07:27 AM | #8 |
The valley plate is baffled does not flow as well as the valve cover which is free flowing
01-22-2016, 08:13 AM | #9 |
The valley pan breather should be pulling air in at idle to help equalize and replace the air being evacuated via the valve covers & tb path.
Under boost the check valve stops air flow back into the catch can. The valley pan is not part of the intake system. If this is getting pressurized at idle or light cruise well you've got bigger issues. This is a street setup. I would contend that for something like road racing with extended high rpm engine operation, MightyMouse would recommend something else. In my case it has worked flawlessly. The diagram is from MightyMouse and he has a much better way to explain how this system would work. I would highly recommend spending the money to buy his products they are very well designed. Sent from my iPhone
Ryker #29
01-22-2016, 12:11 PM | #10 |
Drives: 2009 ZR1 Join Date: May 2010
I have a MM can also. He told me to run mine like this:
Each valve cover has a 10AN bung to an inlet on the can. PCV valve back to intake. I had a 10AN bung welded on the valley cover and it will "Y" to each CAI tube pre turbo. The factory valley cover port is blocked off. |
01-22-2016, 12:34 PM | #11 | |
Way to out water burger me Bro!
Ryker #29
01-22-2016, 12:39 PM | #12 |
01-22-2016, 04:25 PM | #13 | |
Drives: 2010 Camaro Join Date: Nov 2009
Please take a look at this set-up: http://www.camaro5.com/forums/showth...hlight=Jantzen |
01-22-2016, 06:05 PM | #14 | |
