04-02-2020, 11:00 AM | #1 |
Drives: Blown C7 and 6th gen Join Date: Aug 2012
If your getting blown replace that damn front seal with an LS3 seal ;)
So a few months back I had a Maggie installed on my Camaro. Absolutely love it. When I dropped the car off I gave the shop a LS3 seal. When I picked up they told me "That wont be needed with a catch can, your fine". I was disappointed but it was done and I didn't feel like fighting. Well the other car is a C& Z51 with a A&A Ti ProCharger. That car on the other hand has been problematic with blowby, etc. I bought a catch can but had not put it on. Well went out to the car Tue and there was a bath underneath. :( O.K. WTF is this? I did a deep clean, pressure washed, etc. she was spotless again. Yesterday took her out for a nice rough shakedown as anyone would do with a 700rwhp Corvette. None the less come home and my rack along with other parts around dampener are soaked. Well guess what I am starting today? Lucky me gets to drop the electronic rack and pinion to get to the dampener and replace a seal. If it goes in the Camaro in the future I am going to lose my shit. LOL The good news is I did the Procharger on the C7 so I know that car very well. Looks like I am off to the liquor store. Car has 22K don't be Teddy replace the seal boys!!!
14 Corvette Z51 Coupe - 655RWHP
A&A Ti Blower, Alky Control Meth kit, Kooks LT setup, Corsa Catback, Full APR CF kit, RK Sports CF hood, hell CF everything LOL 17 Camaro 2SS 50th edition. TOTALED 6/2019 K&N Intake, MRBP axleback, Eibach kit, 20" Z28 wheels, smoked lights all the way around, Rockford Fosgate system 17 Camaro 2SS 50th edition. Round 2- 8/2019 550/600 RWHP, Magnuson TVS2300, Rotofab Intake, Corsa Xtreme, Air Lift P3 System, 20" Stance SF-07, smoked lights all the way around, Rockford Fosgate system. |
04-02-2020, 11:52 AM | #2 |
Not sure why some shops are not on board with this. But at least now you know why I was preaching to change that seal in your initial thread.
2016 NFG 1SS A8
04-02-2020, 11:56 AM | #3 |
My shop didn't install it either. At the time I was unaware of the issue. I do have the Mighty Mouse Wild catch can setup, so hopefully I'll be OK. It's been 2 years and 25,000 miles.
04-02-2020, 02:31 PM | #4 |
By George I think you are right King.
04-02-2020, 04:40 PM | #5 |
Drives: 2016 Camaro SS 2017 Yukon Denali Join Date: Jan 2020
Not Camaro related, but would this recommendation to swap the seal apply to a l86 Yukon with a 2650 edelbrock?
04-02-2020, 04:50 PM | #6 |
LOL Shut up King!!! OK fine Well it just forced me to order a new Extreme Dimensions ZR1 CF hood (I had to take the RK Sports one came off) and a set of forged Stance wheels ( I had to take the XO's off) HAHAHA I look for any excuse to do dumb shit.
04-02-2020, 04:56 PM | #7 |
04-02-2020, 05:17 PM | #8 |
Time to give big girl some love
04-12-2020, 11:08 AM | #9 |
Owning SSes for 50 Years
Part number
Does anyone have the part number for the LS3 seal? My search shows the same seal for Camaros in years 2010 through 2020? I would like to replace the seal with the LS3 while I'm torn down installing the Super Charger.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
04-12-2020, 01:45 PM | #10 |
Drives: 2018 Camaro SS Join Date: Sep 2009
I don’t see it being an issue at low boost assuming you’re running the kit as it was delivered. If you build something moderate to extreme, as in double digits on the boost, than yes it would be no different from an LT1
04-12-2020, 03:12 PM | #11 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
04-15-2020, 09:31 AM | #12 |
04-16-2020, 10:07 AM | #13 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
Well if there is a front seal issue then it means there is a problem with pressure getting into the PCV system. The stock PCV setup is problematic on a stock engine, much less one that has boost added to it.
Now yes, I have a LS3 seal on my car as I took it apart to do forged internals, but it is best to fix the root cause first. As the difference is with a LT1 seal, it will let air by. The LS3 seal will just get pushed out, or will push something else out. When I first got my car running this year I actually ran it breaking in the cam and such with the hose from the PCV box unhooked to atmosphere and after things warmed up and it was idling, it was pumping a lot of air out of the box in the form of steam. I wanted to see how much pressure there might be, so I put my thumb on there for about 20 seconds and I heard a "Pop". Turns out it pushed the wire harness plug for the oil pump right out of the front cover. Now that the engine and rings are sealed up and everything is hooked up to my catch can, there is a good 10-12hg of vacuum at idle. If you are running any kind of boost, I would suggest a vented catch can solution or you are going to struggle with this.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
Thread Tools | |
