01-21-2020, 11:15 AM | #29 | |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Again, lets have people with this set-up chime in with more information. Thing is, that I would not like to impair the emissions requirements, by deleting the CATs and potentially fail smog tests. Regarding intake: The stock inbox can be modified (I.E. Drill openings at the bottom): i would like to remain with a panel filter too - There has been no significant (if any) gains proven by using a conic/round shaped filter (I.E. K&N, Rotofab, Etc.). Ported TB is already installed BtW (Soler) |
02-11-2020, 03:20 AM | #30 |
Drives: SS 6 speed of course Join Date: Jan 2016
just to finish up on the LT1 cam vs the LT4 cam. I check the LT5 cam specs and it is a DoD delete LT1 cam. exactly: 200 /207 .551 / .524 LSA is 116.5
http://www.superchevy.com/how-to/eng...ed-c7-zr1-lt5/ So the LT1 cam is a better factory performance blower cam.
03-19-2020, 01:10 PM | #31 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
oldman: Verrry interesting...would not have guessed. Thanks for posting.
03-19-2020, 11:57 PM | #32 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
https://www.facebook.com/AdvancedMod...type=3&theater
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 03-20-2020 at 08:26 AM. |
03-20-2020, 02:37 AM | #33 |
wow on that little blower...
03-20-2020, 04:15 PM | #34 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
Well yea - its 20lbs of boost, with a ton of meth and a ice box for the intercooler to chase the heat away.
I run a Alky meth kit and think it is definitely the way to go, especially with a PD blower, but when the sun goes down - the pump is just a $35 motor from a jacuzzi. If you are that meth dependent, it is a grenade waiting to happen.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
03-20-2020, 05:26 PM | #35 | |
03-20-2020, 07:36 PM | #36 | |
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
03-22-2020, 09:05 PM | #37 | |
20lbs on the 1.7 makes a tremendous amount of heat. They are chasing the heat away with the meth and the ice, but it is not a setup you can rely on under boost on the street. On the track where there is a lot more predictable variables it can be planned for - but you will need to put a meth pump in that thing on a regular basis to make sure you dont grenade it.
Thread Tools | |
