06-13-2017, 07:50 PM | #1 |
Drives: 2010 2SSRS Join Date: Jun 2017
Corsa Exhaust question & Black water
Hey guys.
Recently picked up a set of American Racing Headers and a Corsa Exhaust for my 2010 SS Camaro (LS3). Got everything installed and sounds fantastic, but wasn't until I got everything on that I realized the exhaust is corsa's exhaust for the L99. Would it be fine to leave on the car? Or do I need to remove it and go with something else? Also, at the rear of the car on the mufflers, and mid way up, I'm getting a lot of leakage at the clamps. Dark water- Looks to be so and water mixed, condensation maybe? Any thoughts on this and ideas on how to cut it down and get less leakage? I'm in Georgia, so I figure with it being as humid as it is it isn't a big deal. Any info helps. |
06-13-2017, 08:39 PM | #2 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Don't worry about it , you can put a AUTO kit on a M6 just not the other way around. And all exhausts have the black water , from exhaust gas cooling as it travels out (condensation)
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
06-13-2017, 08:50 PM | #3 |
I'm guessing the black in the water is soot mixing with the condensation? Is a large amount of water normal?
06-15-2017, 01:44 PM | #4 |
Drives: Pontiac G8 GT Join Date: May 2009
You should be able to snug the clamps down where they will not leak water or air. -John
www.AmericanRacingHeaders.com
100% USA MADE |
06-15-2017, 03:28 PM | #5 |
Drives: 2014 Ford SVT Raptor SuperCrew Join Date: Jun 2011
Looks normal to me. Just make sure all clamps are snug. Usually have to check after a few heat cycles.
Also a L99 exhaust will fit a LS3 car equipped car and vice versa. Usually the difference is a L99 exhaust might have more to drown out drone or AFM mode. Now an exhaust for a convertible won't work on a coupe and vice versa.
Phoenix (sold)
2014 Ford SVT Raptor SuperCrew How to hug your camaro Buy the car that you would most like to get beat in. The other guy will always be faster. |
06-15-2017, 08:09 PM | #6 |
Good deal. Exhaust leak fixed.
Now considering I've got new headers and an exhaust on and all, Im getting a lot of backfiring, an abnormal amount and Im almost positive it is running very lean. I'll be taking it to get dyno'd and tuned soon, but until then, would the 5/20 fuse pull helpthe car or backfiring any? |
