08-29-2020, 01:41 PM | #1 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
Any ideas ?
So i just removed my rear differential cause of the dreeded clunking..
Was driving me nuts . So i dropped it off to be looked at and hopefully fixed !! So i ordered an DSS aluminum 1-piece driveshaft ! Anything else i can or should do ? Besides a clutch lol ? I did Hendrix off-set differential bushing already , solid cradle bushings.. So any ideas !?!?! Thanks Last edited by Scotty D; 08-29-2020 at 02:08 PM. |
08-29-2020, 01:45 PM | #2 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
If you're going to do the clutch theres a couple of tricks you can do to the trans w/o tearing it apart that help. Look up "CamaroCraka" there's an extra tailshaft bearing and a bronze cup. Also a tick remote bleeder set up is smart. If it's inthe budget I would consider a better carrier like a truetrac or detroit unit.
Sent from my SM-G973U using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
08-29-2020, 01:47 PM | #3 | |
Spring time for a clutch as my budget is tight . Because , I’m out of work right now . Dame coronavirus !!!! |
08-29-2020, 01:48 PM | #4 |
I feel you man, once the clutch happens though. Those other parts are only a few hundred total.
08-29-2020, 01:50 PM | #5 |
08-29-2020, 01:50 PM | #6 |
You too brother.
08-29-2020, 10:42 PM | #7 |
When you’re doing your clutch good time to do a remote reservoir as well less than a 100 bucks.
Orange Krush II
08-29-2020, 11:51 PM | #8 |
