Old 05-15-2020, 07:54 PM   #1
Scotty D
Drives: 2014 1le 1SS CRMT
Engine mounts
I did my motor mounts today
I installed BMR polyurethane motor mounts
Wasnt to bad !!
But having long tube headers made it harder cause i had to remove them !
But all in all not bad
And i did this in my driveway on my back !!!
Scotty D is offline   Reply With Quote
Old 05-15-2020, 08:08 PM   #2
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
it's a good mod...feels much better, right?
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 05-15-2020, 09:19 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Those are the ones I want. My goal is to replace every bushing possible this year.
How do they feel?
InFiD3ViL is offline   Reply With Quote
Old 05-15-2020, 10:07 PM   #4
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Did mine as well with the same ones when i did my build. Little bit more engine "feel" but love the mod. 1000 times better than those crummy stock mounts
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 05-15-2020, 10:16 PM   #5
InFiD3ViL
InFiD3ViL's Avatar
I want more shake with my lope, so if that's on the menu then I'm all for it...along with the other benefits.
Old 05-15-2020, 10:25 PM   #6
Scotty D
Lol i dont know yet cause i still have to put my headers back on
Cant wait though
Old 05-15-2020, 10:30 PM   #7
Scotty D
How do they feel?
I just replace the majority of mine I did BMR lower control arms tire rods trailing arms all with polyurethane plus aluminum Pegasus cradle bushings & hendrix offset differential bushings
Plus the out trailing arm bushing & front inner bushing
I also did aluminum radius bushing inserts
And last but not least Pedder XE coilcovers with the separate reservoir
Old 05-16-2020, 04:52 AM   #8
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
I put in Detroit Speed poly mounts. My whole car shakes along with the lope of my cam. It's awesome.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 05-16-2020, 08:47 AM   #9
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Prothane
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 05-16-2020, 09:43 AM   #10
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Does it make the car vibrate a lot more? That is what I read in past threads about aftermarket engine mounts.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 05-16-2020, 10:40 AM   #11
xc_SS/RS
Drives: 2010 Camaro SS/RS
You’ll feel more of the vibrations for sure but they do soften up after some use
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-16-2020, 01:01 PM   #12
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
I have The bmr mounts with the solid Delrin inserts and it vibrates a lot but there is no movement and instant throttle response.
_Onyx_Wolf_ is offline   Reply With Quote
Old 05-16-2020, 01:52 PM   #13
zz430camaro
Drives: 2015 1LE
vibrates a lot to the point that its annoying, cant imagine that being fun to ride in
Old 05-16-2020, 03:43 PM   #14
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
How did you get delrin? Mine are true solid aluminum pucks, which they offer as an upgrade to the polyurethane. I had never seen them offer motor mounts with delrin "DERLIN" as some say lol, bushings. Mine are sitting on my bench waiting to get installed
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
