dave@hennessey
Old 01-14-2020, 07:52 PM   #1
Stormtrooper_1LE
Stormtrooper_1LE's Avatar
Drives: 2015 2SS 1LE + 2023 2SS 1LE
Kooks high flow cats with SE headers
Does anyone know if the Kooks high flow cats will bolt up to the speed engineering headers without fabrication? Also is there any significant difference between Kooks part #22503201 and part #GE-307540 and would either work? I attached the links to both parts.
https://bit.ly/2QUi8xa
https://bit.ly/2NsvEWy
Thanks in advance!
Stormtrooper_1LE is offline   Reply With Quote
Old 01-14-2020, 07:55 PM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
There's no flange on the speed engineering headers and no ball/cup. It's just a straight 3"outlet
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 01-14-2020, 08:42 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I bought the ball cup and welded them on to the headers for easy on/ off... fyi
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 01-15-2020, 08:29 AM   #4
Greenhornet2
That's a good idea. Might look into that myself. I am taking them off shortly to get ceramic coated.
Old 01-15-2020, 01:59 PM   #5
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Get some Texas Speed high flow cats to go with your Speed Engineering headers. They will bolt right up without any modifications needed. Kooks will need to be modified or your Speed Engineering headers will need to be modified. If you haven't already bought the headers yet, just give the TSP guys a shout and order a set of their headers from them with high flow cats. That's the easiest solution and the price difference isn't much different.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 01-15-2020, 04:44 PM   #6
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
If you already have the Speed engineering catless pipes I have Texas speed cats we could possibly work out a deal.
SSkat is offline   Reply With Quote
