06-30-2017, 08:31 AM | #1 |
BUMBL Z
Fuel pressure gauge install
Trying to install an AEM gauge to monitor fuel pressure under boost. Has anyone installed one of these with the fuel rails on the magnuson tvs2300? Trying to figure out where I can install the sensor for the gauge
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
07-05-2017, 12:19 PM | #2 |
BUMBL Z
No one?
07-05-2017, 01:04 PM | #3 |
Drives: Highly Modified Join Date: Oct 2016
Are you trying to add an adapter that threads between the line and the rail, or are you open to adding a tee into the hose section? This looks simpler on the LSA than the LS3 (based on pictures) but pretty straight forward nonetheless. If you had an inline filter, you could also just add onto there, but I believe it is just integrated into the pump. The AEM sending unit only has a 1/8" NPT thread.
-AL of SDTW Direct |
07-06-2017, 04:11 PM | #4 |
ive heard you should get your pressure readings from the rail but I don't have a port for a pressure gauge with my rails that came with the slp kit.. I was wanting to do the inline t adapter? but not sure how accurate it will be?? anyone use this method and have pics?
2014 SS/RS blackwing CAI. LTH. 3inch X pipe exhaust to NPP mufflers. SLP TVS 2300. 1LE strut tower brace. 5.1 short throw shifter. BMR trailing arms. poly cradle mount bushings. 559HP/543TQ
07-06-2017, 11:21 PM | #5 |
BUMBL Z
I'm open to anything that would work honestly
Sent from my Pixel XL using Tapatalk
07-07-2017, 10:18 AM | #6 |
Drives: 2013 Camaro SS (+RS) + Hurst+ DME Join Date: Sep 2012
Poor man's approach-
I got a X4 tuner with my Procharger kit, I use that with their software on my laptop to datalog fuel pressure along with engine load, RPM, throttle position, MAF etc and I get a pretty good idea of the fuel pressure drop during boost. I don't know what you have available but there are some cheap OBD connectors with wifi/bluetooth out there where you could monitor it on your phone while driving. If you prefer the more traditional gauge that's a different story though. |
07-07-2017, 04:03 PM | #7 | |
BUMBL Z
07-07-2017, 04:05 PM | #8 | |
BUMBL Z
07-08-2017, 08:21 PM | #9 |
Drives: 2015 1SS 1LE Join Date: Sep 2015
Nitrous Express part number 16185.
07-09-2017, 09:17 AM | #10 |
Drives: 2011 2SS Inferno Orange Join Date: Oct 2013
You can get a Schrader adapter, you remove the valve from the fuel rail and either install gauge under the hood or get lines and mount elsewhere.
2011 Camaro SS
Buckets of money under hood! |
07-09-2017, 10:22 AM | #11 |
Drives: 2SS/RS L99 ABM Join Date: Aug 2009
This is what I did
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
07-10-2017, 10:47 PM | #12 |
BUMBL Z
Bam, looks like just what I needed to make this as clean as possible. Thanks man!
