01-27-2017, 09:16 AM | #1 |
Drives: 2010 camaro 2ss Kooks 1/78 btr3 391 Join Date: Jan 2017
391 gears
Have 2010 Camaro ss, would like to put 391 in it, I would like to find a complete rear end, also I think some years came with 391s stock would that rear end fit mine. thanks
01-27-2017, 09:19 AM | #2 |
Drives: 2012 RS/2SS, 69 ProStreet Camaro Join Date: Oct 2011
They were the stock gears in the 1LEs.
01-27-2017, 09:22 AM | #3 |
thanks would they fit in a 2010ss, with my axles
01-27-2017, 11:01 AM | #4 |
Drives: 2015 1SS / RS NPP Join Date: Apr 2015
If you're going with just gears, on the stock diff, in the stock housing, yeah, they'd fit, I would think.
I'm not an authority on the difference between the model years, but I'd suspect if you're buying a prebuilt diff, gear, housing set from one of the vendors, then it would be a direct swap out for your existing setup. It was on my 2015 SS. I got a eaton true-trac diff, with 3.91:1 gears, pre-built from the folks at JDP, and it was a pretty straight forwad swap. I also upgraded the rear upper control arm bushings to Z/28 bushings, and did the subframe bushings, Detroit Speed solid aluminum, while everything was apart. You might want to think about doing whatever other upgrades you might want to do in that area of the car at the same time. Mine's an LS3. Not sure if you're running manual or automatic. For the LS3, I'm of the opinion, this is how it should have come from the factory. One word of warning though, 1st gear becomes ridiculously short if you get on it at all. Redline happens ridiculously quickly. If I'm looking to act like a civilized driver, then I sometimes just start in 2nd, or am very gentle with the throttle when starting from 1st. |
01-27-2017, 11:08 AM | #5 |
Recalled user
Drives: '12 Camaro SS, '18 Colorado Z71 Join Date: Mar 2009
I've heard this from a few folks. Considering going in that direction as well. So no regrets?
2012 2SS 45th AE LS3 M6 Borla ATAK Catback Kooks Stepped LT Headers CAI Intake Hexvents VMAX CNC Ported Throttle Body RX Catch Can Hurst Short Throw Shifter Pfadt ZL-Spec Stage 3 Suspension Forgestar F14 Tuned by Frost |
01-27-2017, 11:19 AM | #6 |
Drives: 2010 IOM SS/RS L99, Kooks LT, VTC, Join Date: Dec 2016
I don't know if anyone else had this issue, but the programmer I bought did not include 3.91 gears as an option to calibrate the speedo... I think 3.73's and 4.11's were the choices.
01-27-2017, 11:30 AM | #7 | |
Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
With some math work you could figure out the difference and add it to the tire size and get it accurate. Would suck every time you changed tires. |
01-27-2017, 12:19 PM | #8 |
running manuel trans, thanks guys
01-27-2017, 12:26 PM | #9 |
if I understand this right in 2015 they went to 9 inch rear with 391s
01-27-2017, 12:32 PM | #10 |
Drives: 2010 Camaro SS Join Date: Dec 2006
You've got a few options for the 3.91...
Buy a complete 1LE diff (look in the classifieds here...or ebay) Buy a 3.91 gear set and have it installed (cheapest option) Buy a 3.91 gear set and Eaton Trutrac and have it installed If you plan to go with big power build (500+ rwhp)...you should opt for the Trutrac. And lastly...if you really want a robust rear end...you can go for a ZL1 differiential swap. You need the diff, driveshaft, and axles. This is extremely robust and can handle big power. But you've only got the gear choices of 3.23 or 3.73. |
01-27-2017, 12:33 PM | #11 |
[QUOTE=bses48;9527943]if I understand this right in 2015 they went to 9 inch rear with 391s[/]
SS or 1LE? |
01-27-2017, 02:46 PM | #12 |
not sure
01-27-2017, 04:12 PM | #13 | |
Still got over 20mpg highway on the way home for Christmas and back, about a 1200 mile round trip. For calibration's sake, mods so far are 1LE suspension, solid subframe bushings, Z28 rear upper control arm bushings, ported throttle body, Z28 CAI, and 3.91's on an eaton true-trac. Remote tune by Ted Jannetty. |
01-27-2017, 05:45 PM | #14 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
If you are looking for a complete new rear end swap, you should look into the GMPP ZL1 rear end upgrade. That's what I did. You get everything (new rear end, axles & drive shaft) and it'll come with 373 gears (for the M6) which are a lot more street friendly than the 391s. Plus, it'll handle most power adders.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
