Old 08-26-2012, 04:08 PM   #1
camslambam
Drives: 2010 SS, 06 SRT10 Ram
Burnout not working
Brake pedal to the floor the whole time
What would I need so the torque doesn't overpower my brakes so I can light them up?
And yes those are slicks.
camslambam is offline   Reply With Quote
Old 08-26-2012, 04:11 PM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
How about a line lock for starters.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 08-26-2012, 04:13 PM   #3
Supercharged SS
Drives: 2010 Camaro
You prob just need someone who knows how to drive!!!
Supercharged SS is offline   Reply With Quote
Old 08-26-2012, 04:14 PM   #4
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Line lock... water box.
pouncer72 is offline   Reply With Quote
Old 08-26-2012, 04:14 PM   #5
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
This.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 08-26-2012, 04:27 PM   #6
ardailsmith
ardailsmith's Avatar
Drives: 2012 2LT LFX A6 RS Black on Black
Try turning off your traction control. First read and watch this http://www.wikihow.com/Do-a-Burnout
Modern Pony Car is a personalized newspaper built from articles, blog posts, videos and photos selected by Ardail Smith http://paper.li/ardailsmith/1337204572
ardailsmith is offline   Reply With Quote
Old 08-26-2012, 04:28 PM   #7
BowtieBelle
I just assumed the traction control was off then again I can't see the video on my phone..
Old 08-26-2012, 04:32 PM   #8
Supercharged SS
Drives: 2010 Camaro
Originally Posted by BowtieBelle View Post
Had one on my 4th gen Z/28. When you're putting out that much power a line lock generally goes without saying. but we tracked the Z/28. Put the line lock in when we added subframe connectors and drive shaft loop.
I don't run a line lock and I've never had any issue doing burnouts. On an newer auto car, with a gd braking system, he should be able to do a burnout.
Old 08-26-2012, 04:33 PM   #9
Supercharged SS
Drives: 2010 Camaro
At his power level you can blow right through the T/C.
Old 08-26-2012, 04:47 PM   #10
lexlueger
lexlueger's Avatar
L.locks are little easier on the brakes and ABS etc.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 08-26-2012, 05:06 PM   #11
Supercharged SS
Drives: 2010 Camaro
No doubt. You're 100% right but something happened which isn't allowing the front brakes to hold anymore. I'm under the assumption he was able to do a burnout before. I'd rather find out what's wrong before I simply throw the line lic on. Though for him that would be a good mod.
Old 08-26-2012, 08:14 PM   #12
stlrammer
stlrammer's Avatar
Drives: 2017 1SS Blue
ardialsmith has got it down. What he said.
I really never had a problem with it though.
stlrammer is offline   Reply With Quote
Old 08-26-2012, 08:18 PM   #13
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
like everyone says, gotta get a linelock. Works like a charm...
Car doesn't move an inch with the linelock. perfect for getting them slicks nice and warm
AngelSpeedFreak is offline   Reply With Quote
Old 08-26-2012, 09:22 PM   #14
ca2010maro
Zach
ca2010maro's Avatar
Drives: 10 SIM 1LT, 66 F100
That song is now stuck in my head...
2010 1LT
66 Ford F100
Camaro rep for Az ModRod Productions, havent liked us on Facebook? check it out!
http://www.facebook.com/#!/ModRodProductions
ca2010maro is offline   Reply With Quote
