Old 04-25-2019, 12:20 PM   #15
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 ZL1, 2021 Corvette Convertible
Originally Posted by breakskeet View Post
Lucas Oil differential fluid will be fine. Just buy the additive and add it.
There! Someone told you.
Well, I can tell you from experience heat will break down the slip additive faster when it has to be added in separately versus a differential fluid that has the additive already included.
Old 04-25-2019, 12:54 PM   #16
AZ_1LE
Drives: 2019 ZL1 1LE
Originally Posted by SJFGTO View Post
^^^ Yes. No disrespect to anyone, but why would you use a different oil than the one GM engineers specify?
The OEM fluid in the transmission of my old SS 1LE was swapped out for Amsoil's recommended fluid, and the difference was HUGE, plus transmission temps went down 15 degrees on track. You have to remember that OEM's will always work out a deal with their oil suppliers for a balance between a fluid that will be good for its intended use with what is cheapest.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 04-25-2019, 01:05 PM   #17
DANACO
DANACO's Avatar
Drives: 18 ZL1
“You have to remember that OEM's will always work out a deal with their oil suppliers for a balance between a fluid that will be good for its intended use with what is cheapest.”
Really ? Do you know this for a fact ?
DANACO is offline   Reply With Quote
Old 04-25-2019, 04:14 PM   #18
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
In 500 miles of track use?
You will be changing gear fluid much faster than the breakdown of the additive will be. RP has the additive in it already. I add more just to be on the safe side.
breakskeet is offline   Reply With Quote
Old 04-25-2019, 05:03 PM   #19
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
the OEM stuff is synthetic with the Friction Additive already in it, why mess with a good thing?
This "can vs. should" discussion lacks any data pointing to aftermarket fluid being any better than the OEM.
Old 04-25-2019, 05:17 PM   #20
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 04-25-2019, 05:47 PM   #21
AZ_1LE
Might as well run the OEM fluid in the GT4 Spec ZL1 too, right?
Old: 2017 SS 1LE
Old: 2017 ZL1
Old 04-25-2019, 08:09 PM   #22
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
All done, fluid looked like every other brand newgear set @ 1500 miles
gotswap is offline   Reply With Quote
Old 04-25-2019, 09:27 PM   #23
kwav8r
Flyin NOE
Depends. What does the manufacturer recommend?
BTW, what's the maximum velocity of an unladen swallow?
Old 04-25-2019, 10:04 PM   #24
breakskeet
Kevin
breakskeet's Avatar
Exactly!
Nor is there any data pointing to aftermarket being worse.
Old 04-26-2019, 12:45 AM   #25
waterman
waterman's Avatar
Drives: Grandad's C2 L89
African or European swallow?
2018 ZL1 1LE sw/PDR
Old 05-01-2019, 05:16 PM   #26
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
My local chevy dealer is selling the recommended GM diff fluid for $20 a quart
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
