04-08-2018, 07:25 PM | #1 |
Drives: '18 Camero V6 1LE Join Date: Mar 2018
GM part numbers for V6 1LE brakes pads?
Is front brake pad GM 23303281? Is rear brake pad GM 23344220 or GM 23344214?
04-08-2018, 09:13 PM | #2 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
This may or may not help, but the front pads if 4 piston should be the same as SS front pads. They should be the ferodo 1001 pads if i remember right. That's what ive been running the past year.
The rears may be different than the regular v6, but given that its still a single piston rear caliper, chances are you can cross reference them to any regular LT model. Worst comes to worst, check this site.. www.knsbrakes.com I know you can look up pads by make model and trim levels (i.e. 1LE) Outside of that, you can also try inputting your 1LE vin into a site like gmpartsdirect or gmpartsonline, and seeing what part number comes up for your vin.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
04-09-2018, 07:04 AM | #3 |
Drives: 2016 Camaro 2SS Join Date: Mar 2017
23344220 Is the rear pad for the V6 1LE.
Traded-2017 1LT V6 GMPP Intake, Flowmaster American Thunder axle-back, Vmax Ported throttle body, ZL1/1LE sway bars, V6 1LE Suspension,SEMA grille, Blade spoiler, Apex PS-7 18x10
04-10-2018, 07:29 AM | #4 |
Drives: 2018 ZL1 Manual Join Date: Mar 2014
Anyone found a higher temp pad for the rear V6 calipers? I haven’t.
04-10-2018, 11:33 AM | #5 |
04-10-2018, 11:39 AM | #6 |
I have used Hawk front pads intended for the SS.
