03-19-2018, 06:19 PM | #1 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
What Diff in the SS?
What diff do they run in the 6th Gen SS and will the 5th Gen ZL1 diff fit? I know the axels won't.
03-21-2018, 10:21 PM | #2 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
225mm ring gear 2.77 gear ratio.
I do know the mounting of the 5th gen has a horizontal bushing at the rear bottom of the diff, whereas the rear on the 6th gen diff is a flat wall and the bushing is mounted in the cradle itself. So not likely it will fit without some decent fabrication. Added some pics, the one with the cooling lines comin out is the 6th gen diff. The one the guy is working on is the 5th gen. Both are shown from the rear.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
04-10-2018, 05:00 AM | #3 |
the 6th gen ss 3.73 gears in the manual
04-26-2018, 06:09 PM | #4 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
What about the LSD? Any one know who makes it and what kind it is?
04-26-2018, 06:55 PM | #5 |
not sure of the maker, but a clutch plate style... not gears.
Thread Tools | |
