02-06-2018, 09:42 AM | #1 |
Drives: 2017 SS 1LE Garnet Red Join Date: Nov 2016
Brake Fluid Bleed/Flush Experiences?
In preparation for the coming track season I was flushing the stock DOT 3 fluid and replacing it with Motul RBF600. I wanted to let everyone know that I got air out of each caliper. This was an easily driven 2017 1SS 1LE with no track time and only 5800 miles.
I had noticed very early on that while the brakes definitely stop the car the pedal had a bit more travel than I like. Hopefully, this cures it but since it keeps snowing around here I haven't been able to drive it since the fluid flush. I'd recommend that everyone give their brakes a quick bleed since clearly, the factory left some air in mine. Did anyone else see this when they bled their systems? -Dave |
02-06-2018, 09:46 AM | #2 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
I think your experience mirrors most owners. Mine had a microbubble or two, nothing major, but post-bleed with Castrol SRF and the pedal feel was much more normal. It's probable the factory fluid is typical bulk brake fluid, there's no reason for GM to waste money on good fluid if the educated owner is going to flush with quality fluid anyway.
02-06-2018, 02:09 PM | #3 |
Drives: Camaro Justice Join Date: Jun 2007
If there was air in the system, you should bleed the system with a GM USB type tool that also cycles the ABS pump. You could do a traditional bleed and then drive on a wet surface to activate the ABS and bleed again, but that is hit or miss and may require multiple bleeds after ABS cycling.
02-06-2018, 04:39 PM | #4 |
the guys that installed my lines and fluid had a horrible time doing it lol did it clockwise then counter clockwise and still couldnt get all the air out lol glad i paid upfront cause it took them about an hour or so longer than they quoted me
02-06-2018, 05:28 PM | #5 |
__it Happens...
02-07-2018, 04:47 PM | #6 |
Thanks for the responses guys. I can't wait to drive it again!
02-19-2018, 06:46 PM | #7 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
I jist did mine and i had air come out also. 900 miles.
04-20-2018, 04:03 AM | #8 |
Drives: FIFTY 2SS Callaway Join Date: Sep 2017
Hey guys FYI, I was reading through the service manual and it states the sequence for bleeding brakes is:
1. Right rear - inner then outer 2. Left front - inner then outer 3. Left rear - inner then outer 4. Right front - inner then outer I know most people are using a different sequence |
