10-17-2017, 12:21 PM | #1 |
Drives: 2017 1LE - Blue Join Date: May 2017
Broken Moreno Motorsports Camber Plate
http://www.camaro6.com/forums/showthread.php?t=510624
This is carried over from the 1LE section. The link is to the original thread and initially I thought it was only the passenger side. I took my drivers side strut out last night and it was cracked in three places. The pics attached are of the drivers side. Just to reiterate MMS has been very helpful and responded quickly to the issue and they're going to begin testing to isolate/correct the issue. |
10-17-2017, 01:38 PM | #2 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
Wow, that flange is really thin. It doesn’t see any less vertical load than the plate it is bolted to, which appears to be nearly 3x the thickness.
10-17-2017, 04:01 PM | #3 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
OK, now I"m a little scared with this 2 day track event I have coming up in 1.5 weeks. It's already paid for and you can't just take these off because of the modification to the spring seat that had to be done. I'm going to check mine when I get home. I only have one (single day) event on them which was only 3 sessions on a smallish track. Can you see this from below the car without removing it?
11-28-2017, 02:37 PM | #4 |
Drives: 1LE Join Date: Sep 2017
Any updates? Looking for more camber then base 1LE will allow. -3 camber with R7 is what I like to achieve. Or is there some alternate means to get there?
THANKS! |
11-28-2017, 02:51 PM | #5 |
Drives: 17 SW 1LE Join Date: Jun 2017
Last I read MMS modified the design and had sent a new set to Text1LE, I don't think he had gotten them yet.
11-28-2017, 03:13 PM | #6 |
11-28-2017, 05:54 PM | #7 |
another one! in my dj khaled voice lol
11-28-2017, 06:12 PM | #8 |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
Elongate OEM camber adjustment slotted upper hole on the lower strut mount, then grind outer ridge on strut. Voila- -3 up front. Takes 30-45 min, I used a carbide bit. You don’t need to remove much material.
11-28-2017, 06:33 PM | #9 |
11-30-2017, 09:07 AM | #10 |
Update: I've received the new designed flange for the mid-plate assembly and it looks great and a lot beefier than the previous one, it looks like the thickness has doubled or maybe a little more. I have a track day this weekend and I'll provide an update afterwards and also post a pic of the new flange when I get a chance.
Thanks again to Justin for the quick turnaround time on the new part. Moreno Motorsports has been great to work with and I look forward to purchasing more products in the future. |
11-30-2017, 10:00 AM | #11 |
New design
11-30-2017, 03:37 PM | #12 | |
Drives: 2017 1LS White Join Date: Oct 2016
Motorsports sticking by their product and customers. |
11-30-2017, 04:04 PM | #13 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
11-30-2017, 05:50 PM | #14 |
It’s a quick fix you only have to swap out the bottom piece on the pic I posted. If you look at the pics I posted previously the piece that’s cracked is the only revision to the design.
