01-25-2023, 07:13 PM | #1 |
Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
What’s the difference between sport and track mode without MRC?
Is there a difference in NPP exhaust sound or shifting in the two modes?
01-25-2023, 10:22 PM | #2 |
Yes, check out this chart. It's for my 2018, but I'm almost certain it also applies to your 2023 with no changes except for the fact that you also have line lock on your SS, unlike 2016-2018 model year SS Camaros.
NPP valve control tables in the tune are different for sport and track mode, the valves stay open in a wider rpm and throttle range in track mode (although they still do close when cruising on the highway, which is why some resort to the "fuse pull technique" to keep the valves open 100% of the time).
01-26-2023, 08:22 AM | #3 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Throttle response and steering stiffness (Steering stiffness can be set manually though on the touch screen vehicle settings if you don't want it automatically changed) Sport has a higher ratio of pedal to power (less pedal more power) Track is a 1:1 ratio from what people have said on these forums I use track mode when I'm playing around or at the strip. Otherwise I'm in touring most of the time.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
