Old 07-18-2018, 06:28 AM   #1
Skyset
Drives: 2017 Camaro 2SS Coupe
Would this be covered under warranty? (Steering wheel)
It looks like for whatever reason, the top of my steering wheel is starting to peel. Would the dealer replace this?
Thanks!
Skyset is offline   Reply With Quote
Old 07-18-2018, 06:35 AM   #2
crosive
Drives: 18 zl1
I would imagine so. car is too new to be flaking materials, imho
crosive is offline   Reply With Quote
Old 07-18-2018, 06:35 AM   #3
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
They should does not appear to be from a cut.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 07-18-2018, 07:53 AM   #4
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2017 ILE SS
Do you drive with one hand in the same spot all the time? You need to move your hands around a bit more...
Bad Anvil Garage is offline   Reply With Quote
Old 07-18-2018, 08:38 AM   #5
speedup
speedup's Avatar
Drives: 2017 2SS Convertible
My dealer probably wouldnt, they would not replace the lighted camaro door sill after the "C" letter started to lift .. "normal wear and tear" they said.. wtf
2017 2SS, Hyper Blue, 8sp, NPP, MRC
speedup is offline   Reply With Quote
Old 07-18-2018, 08:59 AM   #6
crosive
Drives: 18 zl1
dealers like this bother me. they get paid for the repair, they charge it to warranty work where gm pays for it. It's the same as if they charged you for it and you paid for it.
it's just lazy.
Old 07-18-2018, 09:19 AM   #7
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
A dealer should want to do this. There are huge safeguards in the industry against the dealer claiming to do warranty and then not doing it and collecting the money. It can literally get him thrown off of the program where he can make any decisions at all, and has to phone in every situation that he comes across, to be taken off of "self authorization" via manufacturer is one of the horrific things a dealer fears, so therefore they're very careful about doing the warranty work And not just charging for it. And if they do participate in fraud, then they get put on a watchlist at GM, which is very invasive. They usually get a in person warranty audit once or twice a year where every repair is pulled/printed and looked at , and in many cases the customer called, or the car brought back in and inspected .It can take a couple weeks, With a GM audit person sitting right at your desk…
The steering wheel should be warranted. Even if your hands did it, it's a product defect .So should the door sill mentioned above.
Old 07-18-2018, 10:44 AM   #8
Nsxmatt
Drives: 2017 Camaro
Should be covered. Usually items like this and other leather items that come in contact with the body and cause wear are covered once. Most of the leather issues we see are from larger people sliding into seats or lotion on hands and arms is another that causes leather to peel and separate. If it's from one of those things most likely they will not cover it a second time.
Nsxmatt is offline   Reply With Quote
Old 07-18-2018, 10:52 AM   #9
Bigdog9586
Drives: 2016 Z06 coupe
That’s a lame answer. I’ve drive cars for years in the same spot and never had this problem.
Bigdog9586 is offline   Reply With Quote
Old 07-18-2018, 10:57 AM   #10
GM Lifer
GM Lifer's Avatar
Drives: 2016 Camaro SS in Red Hot
Absolutely covered. The "SS" badge at the bottom of my steering wheel peeled, and the dealer replaced it. I had a 2005 GTO whose steering wheel came with a weird crease in the leather, and the dealer gave me a new wheel. There should be no reason the dealer wouldn't help you.
GM Lifer is offline   Reply With Quote
Old 07-18-2018, 10:58 AM   #11
Bad Anvil Garage
Not lame.
Then you've been lucky for years because its very common for steering wheels to wear and or burnish from continuous hand contact.
Old 07-18-2018, 12:33 PM   #12
Jeb114
Jeb114's Avatar
Drives: 2021 300
Yes its covered
Jeb114 is offline   Reply With Quote
Old 07-18-2018, 12:35 PM   #13
Jeb114
Jeb114's Avatar
Drives: 2021 300
Its not a wear item. its covered under warranty
Old 07-18-2018, 12:44 PM   #14
flaps100
flaps100's Avatar
Drives: 2017 Camaro 2.0 RS
Fully agree, I have had many cars do this
I have had 50 cars in my life and due to this same kind of issue, I learned to adjust where I hold the wheel. If you use the same spot all the time, on just about any material its going to wear, fade, leave a mark.
Had two wheels replaced in various cars for just this reason, now I am more careful. Just go rid of a Jeep with under 12,000 miles on it and it was showed wear spots at 9 and 2 positions.
Not lame.
flaps100 is offline   Reply With Quote
