01-12-2021, 08:20 AM | #57 |
Drives: 2016 2SS Join Date: Apr 2020
My oil life seems to go down pretty rapidly. I'm at about 65% and I've only driven 1800 miles. Mostly city driving.
01-12-2021, 08:34 AM | #58 |
Hot Camaro
01-12-2021, 08:58 AM | #59 | |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
For most, the OLM will likely parallel 1yr or 5Kmiles anyhow... Above, 65%@1800 miles....30%@3600 miles.....0%@5140 miles (approximate)....A little more highway miles might get you closer to 6K miles at 0%... |
01-12-2021, 12:09 PM | #60 |
Drives: 2020 Camaro RS Join Date: Oct 2019
What I do:
First oil change between 1k & 1.5K, second change at 5k on the odometer and all changes after that 5k or 1 year (all my vehicles). I use almost exclusively Mobil 1 & OEM recommended filters. I am trying to convert to following the OLM but it's hard to teach an old dog new tricks. What I think can safely, easily and probably should be done: Follow the OLM. The newest OLM algorithms measure so many systems, factors & parameters it's crazy. Virtually all of the reasons listed prior in this thread for desiring to not follow the OLM, with the possible exception tracking, are accounted for in the algorithm. There's no need to try and outsmart the OLM. The old days of a "dumb" OLM just keeping track of mileage are long gone. Yes, you had to outsmart the older OLM systems and adjust for driving style, usage, etc., because it was going to tell you to change the oil at XXXX miles regardless. However, that is no longer the case. The current OLM recommendations are based on OEM recommended oil (proper weight and Dexos approved) and a properly spec'd oil filter. So if using some specialty oil containing Unicorn urine that's not Dexos approved and/or a "better" non-spec filter, then all bets are off. Then again between the Unicorn urine and the better filter, the oil probably never needs to be changed. (j/k, don't get excited) What I think you should do: Whatever you want, it's your car, time and money. JMHO No expertise implied or expressed
RWT
2020 Camaro RS, V6, 6MT, Satin Steel 2020 Silverado, 5.3L CC, RST, Z71, Shadow Gray 2019 Equinox LS, 1.5L Turbo, Nightfall Gray Metallic |
01-12-2021, 01:48 PM | #61 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
I change my SS's oil once a year. The car doesn't get a lot of miles. I am using a top Castrol synthetic oil and OEM filter. I am reasonably sure that if I had an oil analysis performed, it would tell me I could go longer between changes.
The OLM will run right down to about zero on the one year anniversary of the last change. I usually just go ahead and change it when the number is really low. If something happens to the motor within the 5/60 powertrain warranty (which seems unlikely), I don't want the maintenance records to indicate anything questionable.
01-12-2021, 01:51 PM | #62 |
just so you know the olm will go down to 0 with in a year even if you never start the car.
01-12-2021, 02:01 PM | #63 | |
Sure, why not?
I don't really mind changing it once a year, as that seems to be the general consensus about max time between changes. I do it my self on a pair of ramps and it is pretty painless. What I don't know is if "one year max" is even really true anymore.
01-12-2021, 02:06 PM | #64 |
they all still recommend that but they sell the oil.
01-12-2021, 02:34 PM | #65 | |
Hot Camaro
01-12-2021, 03:38 PM | #66 |
Drives: 2018 ZLE Join Date: Feb 2018
I probably waste a good amount of money on oil changes but I kind of enjoy doing the maintenance with my car lift. I have 4200 miles and did 4 changes and the dealer also did one when I purchased the car with 500 miles on it that I didn't trust. So basically every 500 miles so far. Also did the differential at 2500.
01-13-2021, 07:21 AM | #67 |
Drives: Camaro 2020 2SS VERT Join Date: Dec 2020
GM dealerships here want $200 CDN for oil change. Ridiculous, since i bought the extended warranty, I will make sure i follow all the rules to ensure I do not void this.
01-14-2021, 12:47 PM | #68 |
Ok...True Confessions time...
My last oil and filter change was on 8-16-'18 at 21,126 miles...Mileage now is 22,536. That's 1,410 miles in 2yrs and 5 months...lol... The OLM reads 76% remaining! Think I will change it today....lol...Oil looks clear and clean on dipstick, though...and the two unused 5qt jugs I have of Mobil 1 05W-30 are at least over two years old as well...I don't think that matters...lol... |
01-14-2021, 02:29 PM | #69 | |
Hot Camaro
Odds are that the OLM on the Gen5 cars does not take into account the calendar - only miles. |
01-14-2021, 04:02 PM | #70 |
Drives: 2016 SS Convertible Join Date: Sep 2016
Interesting - I have 3K miles on my oil and 18 months and at 12 months the indicator said to change the oil. 6th gen tho. I have been dragging my feet - had planned to do it before the winter when the car doesn't get driven as much. Guess I missed that by a few months. Will do this month for sure.
