06-22-2020, 11:18 AM | #1 |
MSD WIRE ISSUES?
Got my msd wires and hight temp boots installed a few months ago and no problem. Went to wash car saturday and as i was about to get on freeway to dry off car car started running rough and check engine light and stabiltrack light came on so i pulled over. No leaks nothing hanging not sure what was going on. Limped home used my codeready and P0137 i believe was the code popped up misfire on cylinder 7.
Shot a photo to my tuner and he said check the driver side back plug wire and sure as shit it was hanging off the coil. Alot of curse words and about an hour later i had to fixed and i made sure to hear the click this time anybody else have the same problem?? thanks guys
06-22-2020, 01:20 PM | #2 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I had that issue when a while back when i was getting tuned but it was the rear passenger wire that had become loose after a wot pull. I wish they had a more audible or feelable clicking sound when pushing them on, but havent had a problem since.
06-22-2020, 01:59 PM | #3 |
yea it was weird it was right after i did a pull on the streets also and mine was driver side rear and yea i heard the click this time which is good well see what happens
06-22-2020, 02:02 PM | #4 |
Drives: Camaro 1ss Join Date: Nov 2019
I have these wires and have had zero issues for a year now. Hopefully it was a freak incident for ya
06-22-2020, 02:07 PM | #5 |
hopefully! i definately thought something else was wrong with the way the car was but glad i got it home safe and fixed it easy
06-22-2020, 06:09 PM | #6 |
Drives: like an old lady Join Date: Jun 2012
i noticed they are short. i check mine once a week. haven’t had any come off but they will frequently back off a click. i’m going to check lengths vs some LS wires and see if i can get some that are a bit longer.
nice product other than that...
06-22-2020, 06:45 PM | #7 | |
lol yea f*ck that if it happens again ill probably just throw my stock ones back on
06-23-2020, 12:41 AM | #8 |
to be fair i basically only drive it on the weekends and i check a lot of things beforehand. it sees a lot of...spirited driving, gotta make sure everything is kosher.
06-23-2020, 07:36 AM | #9 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
Wire was probably never 100% on all the way in the first place. Unless you use some dielectric grease on the coil and spark plugs, they are hard to get to snap on.
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
06-23-2020, 09:11 AM | #10 |
This!
2016 NFG 1SS A8
06-23-2020, 10:50 AM | #11 |
i didnt do the install a local shop did and it did have grease on both sides i popped it back on and heard a click so its all good now well see what happens
been like 3 months since i had it installed and i dont drive much either only on weekends so kinda weird happen after i did a pull also btw
06-24-2020, 09:10 AM | #12 | |
06-24-2020, 11:06 AM | #13 |
ohh that sounds fun lol
06-24-2020, 12:26 PM | #14 |
