Old 03-13-2019, 10:03 AM   #1
Raptor Jesus
Drives: Camaro
V6 Cars with lowering springs
Not much help for the V6 cars in the suspension sub forum....
Looking to see what everyone is using to lower their car, V6 cars only. I've always used Eibach in the past but it's a very modest drop and I'd like a little more.
Anyone have any pics of their setups?
Raptor Jesus is offline   Reply With Quote
Old 03-13-2019, 09:30 PM   #2
Tuner2muscle
Drives: 2019 Camaro ZL1
V6 springs
AFE .... perfect drop, no clearance issues, great ride... i'm also running spacers hence the flush look
Tuner2muscle is offline   Reply With Quote
Old 03-13-2019, 09:45 PM   #3
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
I was the test mule for eibach. It is low enough and without any splitter/lip, I still rub entering/exiting certain roads due to how they bank everything these days. I would not suggest paying for expensive front ground effects if you are lowering as it will get damaged.
Speed bumps aren't an issue. Thankfully.
Old 03-14-2019, 08:34 AM   #4
Raptor Jesus
Drives: Camaro
That is a really nice look! How much of a spacer did you do?
Old 03-18-2019, 09:59 PM   #5
Tuner2muscle
22mm
Old 03-26-2019, 04:08 PM   #6
Lach07
Drives: 2019 Camaro RS
Hey Tuner2muscle, how much is the drop on those AFE springs?
Lach07 is offline   Reply With Quote
Old 03-26-2019, 10:24 PM   #7
Tuner2muscle
V6 springs
bout and inch and a qtr but my car is a 1LE and was lower than the RS to start with
Old 03-27-2019, 12:42 AM   #8
Lt Berserker
Drives: V6 1LE
Got the same springs myself on my V6 1le as well...
Good drop, goes in for an alignment on Thurs. Pleased so far.
Lt Berserker is offline   Reply With Quote
Old 03-27-2019, 09:39 PM   #9
Lach07
Nice nice, i’ll look into it man. I just don’t like how the rear looks kinda too tall on the stock springs
Old 03-27-2019, 10:08 PM   #10
Tuner2muscle
yeah i feel ya.. wheel gap is the worst.. i also prefer flush instead of tuck myself.
Old 03-29-2019, 11:36 AM   #11
302Blue
302Blue's Avatar
Drives: 2017 Camaro V6 1LE
Two quick questions if you don't mind my asking:
What's the ride like vs. just having the 1LE setup?
Are those OEM sideskirts or from aftermarket?
302Blue is offline   Reply With Quote
Old 03-29-2019, 08:22 PM   #12
Mr_Jones
DaBatMan
Mr_Jones's Avatar
Drives: "Candi" 2018 2LT RS M6
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride"
MODS: husky floor liners / uniden r7 / plain jane otherwise...
Current Wives: 2018 Camaro 2LT RS MT / 2008 Avalanche 5.3L AFM
Ex-GF's: 2010 VW CC Lux 2.0T/ 2004 Mazda RX-8 GT MT/ 2001 A6 3.0T MT/ 2001 Navigator / 1995 Accord EX MT
Mr_Jones is offline   Reply With Quote
Old 03-30-2019, 10:46 PM   #13
Tuner2muscle
its a bit firmer but i changed the springs within the first week so didn't have it on long
skirts are american authority ZL1 ...wrapped in CF.. awesome!
Old 04-09-2019, 07:11 PM   #14
Lt Berserker
Drives: V6 1LE
Comparison to stock springs - my impressions (can update once I get to the track and to an autox this summer):
1. Initial compression - afe slightly softer and more progressive than oem, but sets quickly upon loading/weight transfer (probly, my assumption, for to being a progressive spring vs a linear spring).
2. Weight transfer - much less body roll while shifting lateral load during transitions.
3. Haven't bottomed out, but be careful my splitter is now lower than many curbs.
4. Advice: alignment, alignment alignment!!! Having crap alignment after install to a nice amount of toe & camber + over 8° of caster up front the car feels spot on. Almost all of not all understand had been dialed out.
However! (Opinion) - due to the spring being progressive and not linear your initial input brake and steering feel a combination of softer and slightly numb in comparison to stock. I don't feel as though there is any loss in ultimate grip, but immediacy of turn in, brake, and chassis feedback is very slightly dulled. Up side - even with a slightly different (softer/numbness) input feel/feedback on initial steering input and spring loadup the transitions from side to side (do to less body roll) feel fantastic. (Feels like I can get more rotation from throttle input and more progressive loss of rear grip)
Overall the car feels a little softer street casual driving, but smoother when really pushing grip limits and takes a set extremely well along with instilling confidence in transitions. Car feels a little less communicative while taking a set, but buttery smooth when it does - less twitch and more glide while throwing its 3500lbs around
Alignment:
CAMBER / CASTER / TOE
front:. -2.3° 8.1° -.02in (out)
Rear: -1.3° n/a .03in (in)
The extra camber up front really helps with dialing out some of the perceived corner entry understeer.
