01-03-2019, 12:10 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2017
335's out back with no problem?
This came up for sale on Facebook and I think it looks amazing. Thinking about doing the same exact thing with mine.. 335's just seem awfully wide. Has anybody else tried this? He said they fit no problem. Lowered an inch..
F35 Cam / LOD X-1 Manifold / SLP CAI / LS7 Lifters / 3.91 Gears / Hooker Blackheart Exhaust / TSP Headers / SLP Underdrive Pulley / MGW STS / Trunnions and all that other fun stuff....
01-03-2019, 01:01 PM | #2 |
Drives: 2017 1SS auto vert Nightfall Gray Join Date: Jan 2017
The widest that you usually see is 315. 335 seems to be pushing it. I went to just 295 with the Eibach pro line springs with one inch drop. No problem unless you hit a hole on the highway. BAM!
Sent from my iPhone using Tapatalk |
01-03-2019, 01:12 PM | #3 |
Drives: 2010 SS L99 Join Date: Sep 2018
What size wheel, how wide?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
01-03-2019, 01:57 PM | #4 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Barely noticeable difference from 315's, but its there....
There's so much room in them rear wheel wells, that I wouldn't be surprised at all that 335's would fit without issue... Not sure if the difference in profile would actually be worth their price. I can get the 315 NT555 G2's for about 250. I reckon a 335 would be about double that..... I say stick with the 315's. |
01-03-2019, 02:20 PM | #5 |
Drives: Camaro Join Date: Oct 2018
Is there a reason you want a 335 over a 305/315?
01-03-2019, 02:43 PM | #6 |
I'll probably stick to 315. Just curious about the 335.. 11 inch rim
01-03-2019, 03:00 PM | #7 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Minimum 11" wheel, not sure what offset you'll need.
01-03-2019, 03:33 PM | #8 |
Drives: 2012 M6 Camaro SS (RIP) Join Date: Nov 2014
There is no logical reason to go wider than 305 unless you're making 500+ at the wheels
That side, steam rollers always add an incredible looking stance to any go fast machine no matter the power it makes.
Speed engineering 1 7/8 LTs, CAI inc Cold Air Intake, offroad connectors, Solo performance axle back with J pipes, tune, and in need of a driver mod LOL
01-03-2019, 04:14 PM | #9 |
Drives: 2014 2SS/RS Join Date: Jan 2018
It all depends on tire manufacturer too. The way they measure the width doesn't have 100% control over what actually sticks out the side. take two of the same size tires from different manufacturers and measure them and you will get different results
2014 2SS/RS LS3/M6
01-03-2019, 04:23 PM | #10 |
Scott's45
Drives: 2012 2SS 45th Anniversary Join Date: Mar 2012
i think the most important thing to remember is the overall diameter of the tires. if you run 335's in the rear, what do you have to run on the front so the computer doesn't throw a fit. and will the front rub with those tires.
2012 2SS 45th Anniversary, Hurst short throw shifter, Stainless Power LT headers, high flow cats, SW Retro Chambered 3" cat back, CAI, Heritage grill, tinted windows, red/silver hash stripes, AAC LED sidemarkers, blacked out turn signals/tail lights, splash guards. 402RWHP
01-03-2019, 05:26 PM | #11 |
Important to note too that 335 over 315 is only less than 7/16 difference each side different. I dont think its an issue.
2014 2SS/RS LS3/M6
01-03-2019, 06:17 PM | #12 |
01-03-2019, 06:25 PM | #13 |
01-03-2019, 06:30 PM | #14 |
I think what he means is a 335 tire doesn't come in a comparable side wall height percentage to match the outside diameter to an available front tire diameter
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
