Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Gen5DIY
Old 09-10-2018, 07:30 AM   #43
laynlo15
laynlo15's Avatar
Drives: 2016 1ss A8, Npp
I think the 427 has the best bore and stroke combination compared to the 416
2016 Camaro 6.2, Magnuson 2650 Heartbreaker, Manley, Livernois cam, stock heads trans/converter/diff. Kentshotrodgarage (M/T,Hoosier, Racestar Wheels), BBK, RPM RB, DSS Griptec Pulley Best 9.41@146 Best MPH 149 1/4, 5.99@119 Best MPH 120 Best 60' 1.35. Magnuson Employee/Driver
Old 09-10-2018, 11:34 AM   #44
ShizzySupra
Drives: 16' Camaro 2SS
Have any of these big crazy power builds ran a number yet? I know Parish got his lined out and he will easily be crazy fast very soon.
@DeathWatchCamaro on Insta
9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s
ShizzySupra is offline   Reply With Quote
Old 09-11-2018, 12:32 PM   #45
laynlo15
laynlo15's Avatar
Just saw Lingenfelters 1000 hp (crank) Zl1 go 9.60s or 9.70s, at the LS Fest. They have the new 2650 Edelbrock but it still didn't go as fast as Shizzy's little 2300 Maggie.
Old 09-11-2018, 02:25 PM   #46
ShizzySupra
Yea...that e force 2650 is going to have a lot of limitations due to design. Dont like their marketing either: no smoke and mirrors. Yet they dont show any dyno runs, dyno sheet, dont list the 103tb as part of how they got to the power level etc. Heck what gear on the dyno did they run it to?
Be curious to know what it trapped and if it was a 10 speed.
Old 09-11-2018, 03:18 PM   #47
laynlo15
laynlo15's Avatar
It was over 140 but don't remember the exact mph
Old 09-17-2018, 03:10 PM   #48
L78toLT1
L78toLT1's Avatar
Are there differences between the CMS & Gwatney piston/rod combos to justify the ~800 higher price for the CMS parts?
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels/6 piston Brembo's/SEMA Grill/Rotofab dry/Pray ported TB/Magnuson Heartbeat with 85mm pulley/Full LT4 fuel system/JMS boost-a-pump/Skidmark Garage E85 Sensor/JRE Smooth Idle Cam/GPI piston/rod kit /APR main, head, balancer bolts/Kooks 1 7/8 headers with high flow cats/JRE remote tuned
Old 09-17-2018, 05:49 PM   #49
Eldi Z
Drives: 16' Seat LeonFR 1.8T 17' SS_1LE_GBA
CMS is CP-Carrillo (known to be costly - especially the rods)
GPI is Compstar-Diamond
Old 05-08-2019, 01:18 PM   #50
Choda
Drives: Turbo 6.2
CMS - $2,499.00 This kit supports 1000+HP
This kit includes:
- I-Beam Rods with H7 Carillo 7/16 Rod Bolts
- Drops Compression (1) full point 10.5:1
- CP Pistons with 2618 Forging Material
- Thick Wall, Heavy Duty Wrist Pins
- Tool Steel Top Ring, Napier Second Ring
- No Balancing Required! Drop In Piston and Rod Upgrade!!
- ACL H-Series Rod Bearings
- Price Includes Shipping To Your Door!
GPI - $1,700.00 This kit is designed to support 1000+HP
This kit includes:
- 6.125 Compstar Connecting Rods
- Maintains OE Compression of 11.5:1
- Diamond Pistons with 2618 Forging Material
- Heavy Duty Pin, Locks, and Ring Package
- Calico - H-Series Standard Size Rod Bearings
For someone like me looking for <1k wheel, I have a tendency to lean toward the GPI kit. Keeps compression and is an upgrade from the factory rod/piston. I would think the CMS cost would align more with 1k+ builds where the better parts would make more sense.
Has anyone done the GPI kit here? Also what gaps are you guys using?
Choda is offline   Reply With Quote
Old 05-08-2019, 02:51 PM   #51
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yeah well it's been quite a bit faster then that since then.
2016 NFG 1SS A8
Options-[2SS Leather/NPP]
Perf. mods-[Whipple 2.9/LPE LT5 TB/Rotofab Dry/LT4 Fueling/Flex Fuel/CA ORP/FM NPP Axle back]
Old 05-13-2019, 10:10 PM   #52
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
This kit includes:
This kit includes:
Yup I used the GPI stuff. I followed the gapping instructions that came with the pistons.. worked out great except i removed too much material on one ring and had to call diamond to get a replacement.
hitmix300 is offline   Reply With Quote
Old 05-14-2019, 07:11 AM   #53
laynlo15
laynlo15's Avatar
We were at Atlanta in April parked right across from Lingenfelter. I talked to Chris and the tuner a lot during those 4 days we were there. They started off in the mid 9.50s@145 or so. Car runs really good for sure, I think the best pass was 9.39@147. I was running 10.00s, tune was pretty far off, I was hoping I'd run a little closer to there times they ran last year, car was bitch rich and finally got it lined out a few weeks back. They'll be getting one of our Magnuson 2650s in the near future to run some comparisons against the E2650 so we'll see where it all ends up. The Speed Engineering vet made over 1000 at the wheels and broke the tranny on a 9.22 pass and had to be towed back to his trailer so I think his pass would have been really low 9 or possibly high 8 if the tranny hadn't failed just past the 660.
Old 05-14-2019, 06:00 PM   #54
Eldi Z
Did you weigh the stock parts and compared to the weight of the GPI parts?
Would be interesting to know if the weights are actually the same, which would then really mean that no balancing is necessary.
How many miles on the motor since the build?
What kind of max WHP/TQ are you running and on which tune?
Octane?
Did you also upgrade the fuel system to LT4 parts?
Old 05-21-2019, 07:26 PM   #55
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Octane?
No I trusted their engineering and research.
I've put about 500 miles on the motor since i built it. I'm guessing it's around 1000 wheel on 20psi with e85.
the motor has lt4 fueling and the car also has a mega-squirt controlling 8 supplementary injectors.
The engine shows no signs of any issues and sounds/acts perfectly fine. no rattles or vibrations so i'm guessing the balance of the assembly is close.
Old 05-21-2019, 08:12 PM   #56
ShizzySupra
needs moar!
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
