Old 10-14-2020, 04:02 PM   #1
JasonGofast
Used to own a ZL1
Drives: '16 Z06
Does nitrous require fuel upgrades?
Been considering nitrous lately but I don't know much about it. I understand the dangers involved, but have seen quite a few people using it reliably without any issues. One of the main questions I have is...does it require fuel upgrades? Can you use it on a engine that is already near its limit on fueling?
JasonGofast is offline   Reply With Quote
Old 10-14-2020, 05:29 PM   #2
LT1ornothing
Drives: 2020 LT1 M6
Varies by modification and how taxed the current fueling set up already is. A naturally aspirated lt1 can spray up to a 200 shot on the factory fuel system. On a supercharged or turbo lt1, I would only consider nitrous on a stand alone set up with its own dedicated fuel delivery system (fuel cell, etc), otherwise the fuel system will need to be upgraded to accommodate the nitrous.
Old 10-14-2020, 05:56 PM   #3
JasonGofast
Used to own a ZL1
Drives: '16 Z06
Exactly what I needed. Thank you for the information.
Old 10-14-2020, 05:56 PM   #4
supersportss
Drives: 2019 SS
Yes a GM plate system is good for a 200 shot all day long, I recommend an AFR gauge to monitor though. AFR around 11.5 to 12.2 also a hobbs switch to monitor fuel pressure. It'll be fast. PM me if you need help.
supersportss is offline   Reply With Quote
Old 10-14-2020, 06:35 PM   #5
Paintslinger16
Two Lane Blacktop
Paintslinger16's Avatar
Drives: '18 Camaro 2SS
Look up Jorgelovesspeed on YouTube for his nitrous setup, he’s a member here also
i would swap neighbors before i swapped exhaust
Paintslinger16 is offline   Reply With Quote
Old 10-14-2020, 10:45 PM   #6
Juiced1
Drives: 2012 2SS CAMARO 45th
That stock pump is only good for about 650ish. The nice thing about nitrous is that it won't require a high side upgrade or tax the injectors. You can pair it up with a low side upgrade if necessary.
Juiced1 is offline   Reply With Quote
Old 10-20-2020, 03:33 PM   #7
jorgesvlog
Drives: 2019 Chevrolet SS
From what i have seen online and around me, if you are running nitrous and have just a bolt on set up the most you should rely on to be safe is a 150, If you have heads and cam you might be able to do a 150, but if you are spraying a 150 or more, i would recommend a stand alone fuel system which you can fill up with higher octane fuel like c16 or ms109 to ensure you are feeding the car exactly what it needs and not worry about a lean spike or lower octane fuel that could cause pre detonation. I run a 175 shot with c16 in a stand alone and still pull 6 degrees of timing and the car runs great has gone through over 6-7 15lb bottles without a hick up.
jorgesvlog is offline   Reply With Quote
Old 10-20-2020, 06:24 PM   #8
s346k
s346k's Avatar
Drives: like an old lady
the op drives a ZL1, i think.
also, any difference in a ss 1LE vs a base ss with regard to low side fueling?
Old 10-20-2020, 08:16 PM   #9
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
The SS 1LE has the ZL1 low side pump already installed. The HPFP and injectors are the same between SS and SS 1LE though.
Old 10-20-2020, 09:00 PM   #10
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I've never really looked into nitrous, so I don't know much about it either. My thing is it seems like it isn't worth it since its not there all the time and I'm not exactly sure but I think a bottle goes pretty quick and you also need a inconspicuous area to mount it. I run E85 100% of the time, but I don't really see anyone run E85 with nitrous but I see no reason why I wouldn't get the same benefits with E85 as using race fuel and a stand alone fuel delivery system?
cmitchell17 is offline   Reply With Quote
Old 10-20-2020, 11:41 PM   #11
gtfoxy
Drives: '21 Wild Cherry ZL1
It’s definitely an on demand kind of thing.
How long a bottle lasts obviously depends on how much volume you are running & how big the bottle is.
I’ve ran a range of a 75HP dry system to a 250HP wet 2-stage. It got to the point I was burning 2 20lb bottles a week. It’s great until the bottle runs dry.
Old 10-21-2020, 06:28 AM   #12
wnta1ss
Drives: 2017 Camaro 1SS
Very important point there which keeps happening. People don't say exactly what they are talking about and then answers don't fit the car. OP lists a ZL1 in his profile and said that he is nearing the limits of the fuel system already. Therefore IMO it would be foolish to tap off the low side for a nitrous system on this car. The much smarter way to go IMO would be to use a standalone fuel system for the nitrous.
Old 10-21-2020, 07:45 AM   #13
JSH
JSH's Avatar
Drives: '20 ZLE
My stock fuel system supports my 850 flywheel and 730 rear wheel HP, using only boost as the adder. I would advise against two power adders.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650.
100+ octanes, no eth, no meth, no N2O.
2/23 - 1031/1004 wheel.
4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes).
2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next.
Old 10-21-2020, 08:43 AM   #14
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
2016 NFG 1SS A8
Options-2SS Leather/NPP
