Old 12-02-2020, 09:24 AM   #1
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
M6...5th and 6th gear hard to go into at high speeds
I'm having the same issue as I did on my 5th gen.. if I make a pull in 4th and car is traveling 140s/150s 5th gear does go into easily after I struggle or car drops a little speed the car will go into 5th then I run into the same exact thing in 6th.
No other problems with transmission I've tried stock trans mission fluid, royal purple and Mobile 1...
Tremec claims they have never heard of this yet I can find post on the net and I found some rebuild t56/6060 places that use carbon rings to correct this problem from 1st to 2nd and 3rd to 4th.
I haven't tried no lift shifting yet at that speed.
Old 12-02-2020, 12:35 PM   #2
s346k
s346k's Avatar
Drives: like an old lady
?? by default, it isn't going to shift as easily as 1-4
hit it with your purse
Old 12-02-2020, 02:34 PM   #3
DorsoDuroJohn
Drives: 2021 Camaro LT1
I'm having the issues you are describing in 3rd gear. the others are good. 3rd is a beetch. Additionally, tremec 6 speed does not like cold weather, like below 40f that is in general in my 5 weeks of ownership experience.
But i'm talking about normal speeds here too. Not track speeds like you are referring to.
DorsoDuroJohn is offline   Reply With Quote
