Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 05-14-2019, 09:45 AM   #1
PFYC
PFYC's Avatar
Drives: Yes
ACS T6 Splitter for 2016-2018 Gen6 Camaro SS
Give your Corvette and look by adding or changing out your stock splitter on your new Camaro and adding the impressive T6 splitter. You can choose to add to add side winglets to the splitter please make the selection above. Form and function are key elements of the new T6 Splitter for the 2016-2018 Camaro SS. This composite splitter is durable and functional while being very driver friendly. At speed, the splitter works to create downforce, improving handling.
A raised central area provides ramp angle, providing needed clearance over steep driveways. It also improves the airflow to the horizontally mounted transmission cooler.
Let's not forget that it looks incredibly aggressive, setting your 2016-2018 Camaro SS apart and turning heads wherever you go.
Installation is less than 15 minutes and is simple, utilizing the stock mounting bolts. Fits all 2016 2017 2018 Camaro SS front fascias.
The optional winglets offer dramatically improved air flow and an great finishing touch. Over the last few decades, winglets have been used by both commercial and corporate jets. Jet designers have long known that airflow off the end of a wing caused drag. With the implementation of the winglet airflow is dramatically improved. Same principal applies to the latest Camaro Winglets / Deflectors line.
Both the splitter and optional winglets are offered in Primer finish or painted in Carbon Flash Metallic Black.
Save 6% off your order!! Use promo code: SAVESIX
PFYC is offline   Reply With Quote
Old 05-16-2019, 11:33 AM   #2
PFYC
PFYC's Avatar
Drives: Yes
Old 05-17-2019, 01:52 PM   #3
PFYC
PFYC's Avatar
Drives: Yes
Order yours today!
Old 06-03-2019, 11:42 AM   #4
PFYC
PFYC's Avatar
Drives: Yes
Old 10-28-2019, 08:14 AM   #5
PFYC
PFYC's Avatar
Drives: Yes
https://www.pfyc.com/CO1025.html
Application
[IMG]https://www.pfyc.com/mm5/graphics/new/co1025.jpg[/IMG
Old 07-29-2020, 02:58 PM   #6
palindrome-1H
palindrome-1H's Avatar
Drives: 2017 Camaro 2SS Fifty Edition
$568.10 for Carbon Flash paint and not actual carbon is kind of steep.
palindrome-1H is offline   Reply With Quote
Old 06-09-2021, 07:22 AM   #7
PFYC
PFYC's Avatar
Drives: Yes
Application
PFYC is online now Report Post
Old 11-03-2021, 07:34 AM   #8
PFYC
PFYC's Avatar
Drives: Yes
Order yours today!!
