Old 07-16-2018, 06:40 PM   #1
Tenfive
Tenfive's Avatar
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6
So I found out I have the quickest stock tune camaro in the country
Raced in the SS class only intake and exhaust mods allowed no mt drag radials allowed etc unfortunately went out in the semifinals this weekend at camarofest . Thx to dan larry mark jon and the rest of the crew who helped . Gotta feelin there might have been water or moisture on the track at the hit and congrats to tim for making the finals .
Home of the
Quickest stock tune SS camaro vert at camarofest
Tenfive is offline   Reply With Quote
Old 07-17-2018, 08:46 AM   #2
z28pat
z28pat's Avatar
Drives: 2002 z28, 2018 2ss 1LE
That's awesome, what mods do you have and what was your best run?
z28pat is offline   Reply With Quote
Old 07-17-2018, 09:15 AM   #3
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Quickest stock tune? They all have the same tune from the factory this makes no sense?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 07-17-2018, 09:17 AM   #4
Tyl3r
Tyl3r's Avatar
Drives: Camaro 2LT
Originally Posted by ICTsccaCamaro View Post
Quickest stock tune? They all have the same tune from the factory this makes no since?
I'm glad somebody said something. I have no idea what this means.
Tyl3r is offline   Reply With Quote
Old 07-17-2018, 09:17 AM   #5
z28pat
z28pat's Avatar
I think he means that it doesn't have an aftermarket or tuner done tune
Old 07-17-2018, 11:32 AM   #6
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
So, you raced every Camaro in the country? You must have been there for weeks! Wait, mine wasnt there. :-/
Maybe you were the quicker one there, but has more to do with driving skill than the tune as factory cars are nearly identical stock.
Cgocifer is offline   Reply With Quote
Old 07-17-2018, 12:03 PM   #7
my1stchevy
Drives: 2016 Camaro HBM 2SS NPP MRC
Oh the clickbait...
my1stchevy is offline   Reply With Quote
Old 07-17-2018, 10:25 PM   #8
Tenfive
Tenfive's Avatar
at camarofest youre allowed to change tires ( no 00 treadwear drag radials ) exhaust mods ok and intake mods ok .
Tune and other bolt on parts are not allowed.
While the car has run much much quicker in cold air (11’s ), the KY heat and humidity kept us in the mid 12s all weekend..
Old 07-17-2018, 10:27 PM   #9
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 07-17-2018, 10:30 PM   #10
Tenfive
Tenfive's Avatar
No just the fastest ones from across the country that showed up ,from TN,Fl,Va,IN ,TX,MO,NC,SC,AL,OH,IL,MI,MS,IA,PA,MS
So you’re welcome to come next year , just sayin’
Rules are intake and exhaust mods ok , tires ok up certain treadwear no 00 or Mt dragradials allowed.
Old 07-17-2018, 10:37 PM   #11
Tenfive
Tenfive's Avatar
I run my own propeirtary drop in filter with stock box , exhaust mods are limited to cat back only . Stock intake manifold and exhaust manifolds .
In good air 11.90s at 116 @ camarofest with 3000DA heat and 97 degrees and crazy heat plus horrid track conditions 12.42 and 12.44
Both the 1st and 2nd best times . I didnot have the highest mph ( I have a vert )
But thanks to all the great competitors . I won on a holeshot when I spun on one of the rounds . Car had bad vibration and tire shake on the semi final round ..
Finished 2nd in my class at autocross. Brakes were shot and concentrated on the semifinals in the drag race round .
Congrats to all the folks who showed up at camarofest , you really are true chevy lovers and you’all have some fast ass cars !
Old 07-18-2018, 11:58 AM   #12
Timeless
Timeless's Avatar
Drives: 2019 Mustang GT / CS
So is this against other verts only or you beat out all the coupes too?
Timeless is offline   Reply With Quote
Old 07-18-2018, 03:00 PM   #13
Tenfive
Tenfive's Avatar
Against any SS coupe or vert
Old 07-18-2018, 03:17 PM   #14
Nsxmatt
Drives: 2017 Camaro
I think the more appropriate title would be you won a class at Camarofest. You're not the fastest in the country by far.
Nsxmatt is offline   Reply With Quote
