09-16-2021, 09:32 PM | #1 |
Drives: 18 ZL1 - M6 Join Date: Mar 2019
So Long LT-5
09-16-2021, 09:50 PM | #2 |
D3RPZILLA
Is the only difference between the LT4 and LT5 is the supercharger (and I think dry sump vs wet sump)?
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
09-16-2021, 10:12 PM | #3 |
Drives: 2019 Camaro SS Join Date: Nov 2020
09-17-2021, 02:10 AM | #4 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
https://gmauthority.com/blog/gm/gm-engines/lt5/
Overview The LT5 debuted with the 2019 Chevrolet Corvette ZR1, as the powerplant advanced the Corvette’s supercharging legacy, which began with the 2009 sixth-generation ZR1 and continued with the 2015 seventh-generation Z06. The LT5 still delivers the highest output ever for a Chevrolet production vehicle, thanks in part to a more-efficient supercharger system that offers 52 percent more displacement than the Z06’s LT4 supercharger. Since the unit is larger, it can produce more boost while spinning less, which means less heat under the hood. While the blower is intercooled, heat soak can still sap performance in harsh conditions. GM’s first dual-fuel-injection system, which employs primary direct injection and supplemental port injection, also helps the LT5 achieve its record output of 755 horsepower and 715 pound-feet of torque, though the official Chevy Corvette intake added up 17 horsepower. Prior to GM’s official announcement of the 2019 Corvette ZR1 and the LT5, we had the following information about the LT5. General Motors first filed for the LT5 trademark with the United States Patent and Trademark Office on April 2013 in the goods and services category as “engines for automobiles, sport utility vehicles, trucks and vans”. GM subsequently filed a second filing citing the same goods and services category in September 2016. Specifications Type: 6.2L Supercharged V-8 GM RPO Code: LT5 Displacement: 6.2-liters Configuration & Cylinders: V8 Vehicle Engine Orientation: Longitudinal Aspiration: Supercharged Compression Ratio: 11.5:1 Valve Configuration: Overhead Valve (OHV) Valves Per Cylinder: Assembly Site: GM Tonawanda plant, New York, USA Valve Lifters: Firing Order: 1 – 8 – 7 – 2 – 6 – 5 – 4 – 3 Bore & Stroke (in / mm): 4.06 x 3.62 / 103.25 x 92 Valvetrain: Overhead valve, 2 valves per cylinder Fuel delivery: Dual – Direct and Port Injection Aspiration: Supercharged Maximum Engine Speed: 6,500 RPM Drive Belt Rib Count: 11 Materials Block Material: Cast Aluminum Cylinder Head Material: Cast Aluminum Main bearing caps: Tri-Metal Crankshaft: Forged Alloy Steel Camshaft: Billet Steel Connecting rods: Forged Powder Metal |
09-17-2021, 05:45 AM | #5 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
Rumor is that this is the replacement for the LT5 motor...
Notice it comes with a retrofit kit so you can slide it into many different types of vehicles. THANKS gm!
09-17-2021, 07:15 AM | #6 |
Hot Camaro
From what I've read, it was installed in less than 3000 2019 ZR1 Corvettes and that is the only year of the only vehicle it was ever put into. So, anyone with one of those specific Corvettes could potentially thank GM for making their car worth quite a bit of money by ensuring it will remain incredibly rare.
09-17-2021, 07:56 AM | #7 |
~$19,000 for the motor may not be such a bad deal.
09-17-2021, 07:57 AM | #8 |
09-17-2021, 08:02 AM | #9 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
What a waste. All that development cost, and to just throw it away. That engine would have been a real asset to so many GM vehicles with a little forethought.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
09-17-2021, 08:52 AM | #10 |
Shadow Gray '19 ZLE M6
Blackwing checks into the chat
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
09-17-2021, 09:07 AM | #11 |
No there are quite a few differences and the LT5 is even stronger. It also is the only engine in the LT line up that has a traditional hydraulic cam/lifter setup with no DOD/AFM hardware internally.
2016 NFG 1SS A8
09-17-2021, 09:26 AM | #12 |
BAMF SS
I don't see why you are excited about this.
I would kill for an LT-5 powered 6th gen.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
09-17-2021, 10:01 AM | #13 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Can you trust an article that leaves it as the LT4 in the ZL1 is "the big stick" in GM's arsenal? No because that is not true. The CT5 V Blackwing has an additional 18 HP (rumored to be heading to the ZL1).
This is why the LT5 is a $30,000 plus engine premium. Everyone Poo Poos me when I ask do you want a $100,000 Camaro? Probably a bit South of that but not by much. And what GM charges for the LT5 has ZERO to do with what Ford charges for the GT500. GM set this engine up to BE low volume. It was never intended to go into other products (unlike the Cadillac Blackwing that died with Omega). 3,000 units x $30,000 is $90,000,000 which likely covered the develpment costs, tooling and the extra piece cost for this engine. So GM likely didn't lose much on this swan song for the C7. Speaking of swan songs, maybe GM tucks a few of these away for a farewell to ICE powered Camaros in a year or so. Fingers crossed......but it won't be cheap.
09-17-2021, 10:43 AM | #14 | |
