09-10-2021, 10:56 AM | #1 |
Drives: 2017 SS 1LE Join Date: Feb 2017
Anyone supercharged on road courses?
Hi all, I have a 2017 SS 1LE and have been tracking my car a bit this past summer. There are ZL1 1LEs running at the track here as well, and we have the same corner speeds but obviously not the same straightaway speeds (smaller tracks). My question is, is anyone running a supercharger and spending a decent amount of time on road courses? If so how is it heat wise? I'm thinking of running a Maggie 2300 as I still feel the car needs a bit more oomph, I don't want a ZLE (suspension is way to harsh for a weekend warrior and road trips). Is it worth it to add a blower to my road course car or if I want a faster car should I get a different car? I have definitely maxed out my 1LE's cornering, braking, and acceleration and am pushing it's limits pretty hard. I've already approached spinouts on a number of corners at my local track (Castrol Raceway Edmonton) and have dialed it back slightly. My wife and I plan to do a lot more tracking going forward and with any luck I anticipate we'll attend at least half a dozen track events per year (Our other car is a 2019 MX5 we're working on setting up for the track as well) so if the blower will keep us going down this path that would be super cool.
The other thing I'm seriously considering is to get some 19" Apex wheels with some more track focused tires (currently running Supercar G3s on stock wheels). The awesome thing is that this car is built so well from the factory I can't think of much to improve it other than a tidbit more power. My instructor took me out in his fully built Mustang boss and our cars are incredibly similar on track (he really built the crap out of his car). My favorite quote from my instructor which I'll adapt to my situation is that "I'm a Porsche GT3 guy on a Camaro budget".
I'm just a car addict looking for a group of alcohol enthusiasts.
"The Lord is my shepherd; I shall not want." |
09-10-2021, 12:34 PM | #2 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
You could do that, but IMO the answer there is to trade up to a ZL1 (non-1LE). Essentially the same ride as your current car but supercharged and has all the proper brakes/cooling/driveline/eLSD cals/etc that are needed to keep the car as reliable and refined as it is right now. Also get a fresh 5-year warranty (including track use) if you can find a new one. Trade-in values right now also make it more of a no-brainer to just switch cars if you can find one.
2017 SS 1LE.
09-10-2021, 02:00 PM | #3 |
Yep I keep running that scenario as well, but realistically it would be another $30k on top of trade-in. You are right though it's the most sensible way forward. It doesn't seem like many people put a blower on the SS for anything other than straight line racing which is why I'm curious about the road course. For way less than $30k I can have a built motor, headers, and a crazy torque curve but then again warranty
09-10-2021, 02:23 PM | #4 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
I wouldn't recommend it. Heat will be an issue, unless you get the right facia and intercooler setup. One of the best things about 1LE is the (relatively in Camaro context) less weight, and natural aspiration, and plenty of cooling to keep panging on it day after day.
If you're looking for more power, you could also look at having the car professionally tuned. There are packages out there which will put you at 550hp crank for about $5k. Been considering this one myself. https://shop.katechengines.com/produ...s-lt1-stage-2/ |
09-10-2021, 02:45 PM | #5 |
Yep this is what I'm worried about most, heat and the tight tolerances of the LT1 piston rings, things could get outta shape real quick.
It is really awesome to be able to hammer this 1LE as hard as one can session after session and still drive home comfortable and worry free. The hottest track day I experienced this summer was 35c or 95F and although the G3 tires got a bit mushy and the brakes had a little bit of fade the rest of the car ran strong. I don't think I've seen those katech packages before, that would be a sweet setup for sure! Keeping it NA would really rock on track as well!
09-10-2021, 02:46 PM | #6 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
What are your laptimes vs a ZLE? In my experience (depending on the track) the SS can lap within 2-2.5 seconds of a ZLE.
09-10-2021, 03:14 PM | #7 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Just putting ZLE wheels and tires (Goodyear SC3R) on my SS 1LE reduced my NOLA Indy Straight lap times (2.72 mile course) by over 2.3 seconds even with brake pads that were overheating after a few laps. If driven by the same person in similar conditions or driven to the same level in similar conditions, there should be a gap that is quite a bit larger than 2.5 seconds between the ZLE and SS 1LE on a track around that length.
09-10-2021, 03:35 PM | #8 | |
I'm really happy with this car overall but since I bought it in 2017 I knew I would be chasing a bit more power so now it's coming down to do I mod this car or save a bit and upgrade to something faster ie. ZL1.
09-10-2021, 03:40 PM | #9 | |
I know that if I was on more of a 'power track' the gap between the ZLE and my SS would be very big but on these smaller tracks it's only a few seconds. How do the ZLE wheels fit on your car? Did you have to grind the front strut and how much do the wheels poke?
09-10-2021, 05:40 PM | #10 |
Yes I had to do the strut mod to avoid needing front wheel spacers and/or camber plates. They poke out quite a bit but didn't rub while driving on track. I also relocated the rear wheel well wiring harness to prevent the tire from rubbing through the fender liner and wiring harness. I would not run wheels that wide regularly on the street because they would probably throw a lot of rocks at my doors even with the ZL1 Addons rock guards.
09-10-2021, 05:45 PM | #11 |
Here's a picture.
09-10-2021, 05:47 PM | #12 |
Shadow Gray '19 ZLE M6
18" wheels would be preferred for a track car and gives you more tire options in the event you want to run slicks.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
09-10-2021, 10:16 PM | #13 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
I have been struggling with that very question for the last couple of years. Exacerbated since I live in Florida so most of my tracking is a Sebring, Daytona, PBIR and the FIRM. Two years ago I picked up a set of Apex wheels and SC3R's. Huge improvement for me that strangely translated to my events on SC3's. I think the added confidence made me faster. I have been debating doing an N/A build, but recently decided to just punt and get a car that is 'fast enough' from the factory. My last car I spent too much time and money trying to make it faster and I would improve one aspect to hit the limits of another aspect. I finally gave up and got the 1LE. Now I am cross-shopping a CT5 Blackwing and a C8 Z06. I know they are completely different animals, but those are the two on my radar. Just waiting until 10/26 to see what the C8Z brings to the table. On the Blackwing side, it's essentially a 4-door ZL1.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
09-11-2021, 12:04 AM | #14 |
Drives: 2020 SS 1LE Join Date: Aug 2020
Check out user NickyBoyRacer. He has a built NA motor and he’s faster than nearly everyone on track.
