08-30-2021, 07:53 AM | #15 |
Drives: 62 Chevy & 2021 1SS/1LE manual Join Date: Aug 2010
I hear a lot that SS lines do nothing. My personal experience with my 21 1LE was immediate firmer pedal with the goodridge lines and dot 4. Big improvement.
08-31-2021, 04:12 PM | #16 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
The Spiegler or Groodridge SS lines are reputable/DOT compliant options. They will add a touch more firmness to pedal feel, but not really all that much. You'll get more modulation pedal feel than firmness. I honestly wouldn't recommend SS lines unless you track a lot for that reason.
As far as pads, if you like the OE pads, but want more of a firm pedal, the Ferodo DS2500 is an option. Those are basically the race version of the OE pads. Same exact characteristics, like dust and noise, but a touch more heat tolerant and a lot less compressibility to the pads material. They last a little bit longer than the OE pads, so far I've noticed, but not much more. |
11-15-2021, 04:41 PM | #17 |
Drives: 2020 Chevy Camaro SS 1LE Join Date: Jun 2020
I am running Giro Disc (Raybestos) ST43 pads front and rear and absolutely love them. They are quite high torque though so being smooth on the street can be a bit tough at times but you do adjust quickly. I don't drive the car every day so the brakes take a minute to get used to.
I have around 10 track days on them and they are quite easy on rotors. No grooving or anything. Even the wear isn't that bad. Noise they are very quiet. I find they only make a little squeak once they get some heat into them and when you are slowing from 5 to 0. But otherwise nothing. I did Goodridge stainless lines. They are nice. Do they make a difference? Not at all. I just did them to do them. Not really something that is a necessity. |
